Performance Difference Between ipp Versions
adem_metin_cali
Hi all,
i use two algoritms (Foreground/Background Segmentation Using Histogram Model and Mixture of Gaussians) to obtain foreground and i use 3 different ipp versions:First one is ipp 6.0.0.062,second one is ipp 7.1.1.119 and last one is ipp 8.0.0.083.I expected more performance  with increased versions but i saw that ipp 6 is best,then ipp 8 and last one is ipp 7.What is the reason of this situations????
Igor_A_Intel
Hi Adem (is it correct to use Adem as your name?),
could you provide an output from ippcvLibraryVersion or at least an info on which cpu you have, what linking do you use - static or dynamic, performance difference you've faced with (in numeric form), OS, ia32/x64, etc. Currently nothing is clear from your post - no any information to help you or to provide an answer.
regards, Igor
Roman_T_
adem metin c. wrote:
Hi all,
Hi, Adem!
I had a very similar problem while migrating from ipp 6 to ipp 7. In my case ipp had a problem with internal threads (ipp<->OpenMP interaction).
I set number of threads to 1.
ippSetNumThreads(1);
After this modification ipp7 became as fast as ipp6.
Roman
adem_metin_cali
regards, Igor
Hi Igor,
First of all thanks for your interest.I have a i7-Q720 and 8 GB ram.I used only one video to measure performance that is 768x576 dimension and ,2 minutes 30 seconds.I used three different ipp versions:IPP 6.0.0.062,IPP 7.1.1.119 and IPP 8.0.0.083.I used Boost library to measure performance.And average performance informations are below:(Hour:Minutes:Seconds.Fractions)
IPP 6.0.0.062=>Average Calculation Time Per Frame=00:00:00.101847(Dynamic Linkage)
IPP 7.1.1.119=>Average Calculation Time Per Frame=00:00:00.125313(Default Linking Method)
IPP 8.0.0.083=>Average Calculation Time Per Frame=00:00:00.112640(Default Linking Method)
SergeyKostrov
Valued Contributor II
>>IPP 6.0.0.062=>Average Calculation Time Per Frame=00:00:00.101847(Dynamic Linkage) >> >>IPP 7.1.1.119=>Average Calculation Time Per Frame=00:00:00.125313(Default Linking Method) >> >>IPP 8.0.0.083=>Average Calculation Time Per Frame=00:00:00.112640(Default Linking Method) A couple of more questions: What C++ compiler and what options did you use? Was it the same C++ compiler for all 3 cases?
adem_metin_cali
Hi Sergey,
First of all thanks for your interest.I used visual studio 2012 ide for all 3 cases.I did not use any special options.I set  few options for some C\C++ and Linker Options for boost library.
Adem Metin CALI
adem_metin_cali
Hi Roman,
First of all thanks for your interest.I examined your post and your problem was about multithrad library according to the intel ipp users guide.But my problem is different because i use always single threaded library.So i don't need to use ippSetNumThreads(1);.
Adem Metin CALI
