Problem in dynamic loading of Ipp Dlls
mahantesh
When we use Ipp library using static linking our application works fine, but when we use the same using dynamic linking application does not work leading to a crash. Is there any reported problem in using IPP libraries dynamically?
VS2008 is our development environment.
Vladimir_Dudnik
In what part of your application IPP is involved? What IPP functions do you use? How do you use them? Are you using any other third party libraries? What is IPP version you link with? What is your target processor?
Vladimir
PaulF_IntelCorp
Hello Mahantesh,
There are no reported problems that would implicate linking with the dynamic libraries in a crash that doesn't occur with the static libraries.
Are you using the thread-safe version of the static libraries or the multi-threaded version of the static libraries? The dynamic libraries are only multi-threaded, perhaps there is an OpenMP library conflict?
Paul
