RTP H264 stream decode Error ?
gcoolman_eric
Hi all,
I want to decode RTP video stream with h264 codec and save it to mpg2 file, so i generate a h264 streamfile
by using rtpdump in wireshark, and execute a command:
umc_h264_dec_con.exe -fyuv420 -i h264dump.h264 -oh264out.yuv,
butalways encountering an error message "Video Decoder creation failed"?
I was wondering if anyone could address this problem for me that would be greatly appreciated.
Thanks in advance.
Eric
Chao_Y_Intel
Hello Eric,
The h264dump.h264 does not look to be correct: Does it include the IDR frames ( like SPS, PPS, video header information).
You can attach the video here, so users here may help to have check.
Chao
gcoolman_eric
Hi Chao,
Enclosed is my test file, please check it.
For decoding RTP streams with h264 codec by IPP, I have two questions below:
1. Couldyou please give me any idea about how to extract these bitstream from packets correctly ?
2. What is the correct video format in order to feed into IPP decoder "umc_h264_dec_con.exe" ?
Eric
Chao_Y_Intel
Eric,
I just checked your file with other tools( FFMPEG etc). It fails as well. The simpleplayer can take the raw H.264 stream (bit stream format).
I am not sure about the output of rtpdump in wireshark. I just did a quick search, it looks it produce a different output here: http://www.cs.columbia.edu/irt/software/rtptools/#rtpdump
Chao
