Replacing ippiResize_8u_C1R
George_D_2
Hi, I am attempting to replace the ippiResize_8u_C1R function as shown at https://software.intel.com/en-us/articles/resize-changes-in-intel-ipp-71, but I am running into some problems. The sample code does not mention the parameters wratio and hratio in the original function. How are these parameters replaced? I have used another example from this site (also missing hratio and wratio) and my destination image is obviously unscaled. I have rebuilt my entire application using ipp8, but I am pretty much dead in the water without the ability to resize my images.
Ying_H_Intel
Hi George,
Right, the x_factor( wratio)    and   y_factor (hratio)  can be defined by srcRoi size and dstRoi size.  for example
       srcSize.width = org_image->columns;
        srcSize.height = org_image->rows;
        dstSize.width = dst_image->columns;
        dstSize.height = dst_image-> rows;
       srcRoi.width = srcSize.width;
        srcRoi.height = srcSize.height;
        dstRoi.x = 0;
        dstRoi.y = 0;
        dstRoi.width = dstSize.width;
        dstRoi.height = dstSize.height;
        srcWidthStep = srcSize.width * 3;
        dstWidthStep = dstSize.width * 3;
        double x_factor;
        double y_factor;
        x_factor = (double)dstSize.width/srcSize.width;
        y_factor = (double)dstSize.height/srcSize.height;
If  you have x_factor and y_factor  , then you can get dst image, width and height.  Or if you have dst image size, then you can get x_factor, y_factor, which will don't need in new resize functions.
Ying
George_D_2
I'm assuming hratio and vratio are used to modify destination size. In any case that seems to work for me.
Ying_H_Intel
Hi George,
        dstRoi.x = 0;
        dstRoi.y = 0;
        double x_factor;
        double y_factor;
Ying
Tam_N_1
Hi George,
I had met this same problem as you and it took me a lot of time to figure out. I would like to give you the code sample:
This is substitute function for ippiResize_32f_C1R. you can change datatype to match your ippiResize_8u_C1R needs:
IppStatus Resize_32f_C1R(const Ipp32f* pSrc, IppiSize srcSize, int srcStep, IppiRect srcROI,
						Ipp32f* pDst, int dstStep, IppiSize dstRoiSize,
						double xFactor, double yFactor, int interpolation)
	IppStatus status = ippStsNoErr;					// status flag
	IppiResizeSpec_32f* pSpec = NULL;				// specification structure buffer
	int specSize = 0;								// size of specification structure buffer
	int initSize = 0;								// size of initialization buffer (only cubic and lanzcos interpolation type use this)
	int bufSize = 0;								// size of working buffer
	Ipp8u* pBuffer = NULL;							// working buffer
	Ipp8u* pInit = NULL;							// initialization buffer
	IppiPoint dstOffset = { 0, 0 };					// offset to destination image, default is {0,0}
	IppiBorderType borderType = ippBorderRepl;		// borderType, default is ippBorderRepl
	Ipp32f borderValue = 0;							// border value, default is zero
	Ipp32u antialiasing = 0;						// not use antialiasing
	Ipp32u numChannels = 1;							// this function works with 1 channel
	Ipp32f valueB = 0.0f;							// default value for cubic interpolation type
	Ipp32f valueC = 0.0f;							// default value for cubic interpolation type
	Ipp32u numLobes = 2;							// default value for lanczos interpolation type
	IppiInterpolationType interpolateType;			// interpolation type
	IppiSize srcRoiSize;							// size of source ROI
	IppiSize resizeSrcRoiSize;						// size of resize source ROI
	// Check pSrc and pDst not NULL
	if ((pSrc == NULL) || (pDst == NULL))
		return ippStsNullPtrErr;
	// Check srcSize and dstRoiSize not have field with zero or negative number
	if ((srcSize.width <= 0) || (srcSize.height <= 0) || (dstRoiSize.width <= 0) || (dstRoiSize.height <= 0))
		return ippStsSizeErr;
	// Check srcRoi has no intersection with the source image
	IppiPoint topLeft     = { srcROI.x				 , srcROI.y };
	IppiPoint topRight    = { srcROI.x + srcROI.width, srcROI.y };
	IppiPoint bottomLeft  = { srcROI.x               , srcROI.y + srcROI.height };
	IppiPoint bottomRight = { srcROI.x + srcROI.width, srcROI.y + srcROI.height };
	if (((topLeft.x    < 0 || topLeft.x     > srcSize.width) || (topLeft.y     < 0 || topLeft.y     > srcSize.height)) &&
		((topRight.x   < 0 || topRight.x    > srcSize.width) || (topRight.y    < 0 || topRight.y    > srcSize.height)) &&
		((bottomLeft.x < 0 || bottomLeft.x  > srcSize.width) || (bottomLeft.y  < 0 || bottomLeft.y  > srcSize.height)) &&
		((bottomRight.x< 0 || bottomRight.x > srcSize.width) || (bottomRight.y < 0 || bottomRight.y > srcSize.height)))
		return ippStsWrongIntersectROI;
	// Check xFactor or yFactor is not less than or equal to zero
	if ((xFactor <= 0) || (yFactor <= 0))
		return ippStsResizeFactorErr;
	// Get interpolation filter type
	switch (interpolation)
	case IPPI_INTER_NN:
		interpolateType = ippNearest;
		break;
	case IPPI_INTER_LINEAR:
		interpolateType = ippLinear;
		break;
	case IPPI_INTER_CUBIC:
		interpolateType = ippCubic;
		break;
	case IPPI_INTER_SUPER:
		interpolateType = ippSuper;
		break;
	case IPPI_INTER_LANCZOS:
		interpolateType = ippLanczos;
		break;
	default:
		return ippStsInterpolationErr;
	// Set pSrcRoi to top-left corner of source ROI
	Ipp32f* pSrcRoi = (Ipp32f*)((Ipp8u*)pSrc + srcROI.y * srcStep) + srcROI.x * numChannels;
	// Set size of source ROI
	srcRoiSize.width  = srcROI.width;
	srcRoiSize.height = srcROI.height;
	// Calculate size of resize source ROI
	resizeSrcRoiSize.width  = (int) ceil(srcRoiSize.width  * xFactor);
	resizeSrcRoiSize.height = (int) ceil(srcRoiSize.height * yFactor);
	// Get size of specification structure buffer and initialization buffer.
	status = ippiResizeGetSize_8u(srcRoiSize, resizeSrcRoiSize, interpolateType, antialiasing , &specSize, &initSize);
	if (status != ippStsNoErr)
		return status;
	//Allocate memory for specification structure buffer.
	pSpec = (IppiResizeSpec_32f*)ippsMalloc_8u(specSize);
	if (pSpec == NULL)
		return ippStsNoMemErr;
	//Initialize specification structure buffer correspond to interpolation type
	case IPPI_INTER_NN:
		status = ippiResizeNearestInit_32f(srcRoiSize, resizeSrcRoiSize, pSpec);
		break;
		status = ippiResizeLinearInit_32f(srcRoiSize, resizeSrcRoiSize, pSpec);
		break;
		pInit = ippsMalloc_8u(initSize);
		status = ippiResizeCubicInit_32f(srcRoiSize, resizeSrcRoiSize, valueB, valueC, pSpec, pInit);
		ippsFree(pInit);
		break;
		status = ippiResizeSuperInit_32f(srcRoiSize, resizeSrcRoiSize, pSpec);
		break;
		status = ippiResizeLanczosInit_32f(srcRoiSize, resizeSrcRoiSize, numLobes, pSpec, pInit);
		ippsFree(pInit);
		break;
		ippsFree(pSpec);
		return status;
	// Get work buffer size
	status = ippiResizeGetBufferSize_8u(pSpec, resizeSrcRoiSize, numChannels, &bufSize);
		ippsFree(pSpec);
		return status;
	// Allocate memory for work buffer.
	pBuffer = ippsMalloc_8u(bufSize);
	if (pBuffer == NULL)
		ippsFree(pSpec);
	//Execute resize processing correspond to interpolation type
	case IPPI_INTER_NN:
		status = ippiResizeNearest_32f_C1R(pSrcRoi, srcStep, pDst, dstStep, dstOffset, dstRoiSize, pSpec, pBuffer);
		break;
		status = ippiResizeLinear_32f_C1R(pSrcRoi, srcStep, pDst, dstStep, dstOffset, dstRoiSize, borderType, &borderValue, pSpec, pBuffer);
		break;
		status = ippiResizeCubic_32f_C1R(pSrcRoi, srcStep, pDst, dstStep, dstOffset, dstRoiSize, borderType, &borderValue, pSpec, pBuffer);
		break;
		status = ippiResizeSuper_32f_C1R(pSrcRoi, srcStep, pDst, dstStep, dstOffset, dstRoiSize, pSpec, pBuffer);
		break;
		status = ippiResizeLanczos_32f_C1R(pSrcRoi, srcStep, pDst, dstStep, dstOffset, dstRoiSize, borderType, &borderValue, pSpec, pBuffer);
		break;
	// Free memory
	ippsFree(pSpec);
	ippsFree(pBuffer);
	return status;
Hope it can help you.
Tam.
ismet_y_
Hi Tam,
I tried your implementation to replace ippiResize_32f_C1R. However, at line 143 I get the following status error under IPP 9.0:
ippStsNotSupportedModeErr ( -9999 )
Why do you think this is happening?
Thanks,Zeki
Valentin_K_Intel
Hi Zeki,
ippiResize* functions do not support the border type ippBorderConst. You should try to use the border type ippBorderRepl at the line 13.
Valentin
