Running IPP Samples 'cannot open ippi.lib' error
postaquestion
I have purchased and installed the intel compiler suites. I have also downloaded the windows code samples at http://www.intel.com/cd/software/products/asmo-na/eng/perflib/ipp/219967.htm#description
So now I am trying to run ipp-samplesimage-processingimage-processing-mfcippiSample.sln
Compiling this code gives me an error:
Cannot open file 'ippi.lib'. I cannot find this file on my computer. I have already installed the Intel IPP, which I received as part of my Compiler Suites product.
Do I have to do a build to create this library? Or can you send me this library?
I am using Visual Studio 2008, and I had to convert the ippiSample project from a previous version of Visual Studio before I could compile and receive this error about a missing ippi.lib file.
Vladimir_Dudnik
The ippi.lib library is import library for IPP DLL dispatcher. It should be located in stublib folder of your IPP installation.
Vladimir
