SSE4a instructions support
maxim-sharabayko
Hello.
We are using Intel IPP library version 5.3. And facing a problems on AMD processors with SSE4a instruction set.
Wich version of IPP library supports this instruction set? How to get this version (what is licensing policy)?
PaulF_IntelCorp
Please read this KB article for detailed information regarding the SIMD instructions supported by the Intel IPP library, through version 6.1.
Understanding CPU Dispatching in the Intel IPP Library
Note that most AMD and Intel processors produced today support the SSE2 and SSE3 instruction sets. The SSE4a instruction set is unique to AMD processors and is not supported by the Intel IPP library. As you can see from the chart in the table above, after SSE3, the library supports the SSSE3, SSE4.1, SSE4.2, AES-NI and AVX instruction sets.
There are also several good articles in Wikipedia describing the differences between the various SIMD instructions sets available today.
Regarding licensing, please review the following KB articles:
Location of the End User License Agreement (EULA)
How do I renew my license?
Development Products Download, Registration and Licensing Help
Intel IPP Downloads, Registration and Licensing
Which Intel IPP libraries are "Redistributables"?
Intel Integrated Performance Primitives - Licensing FAQ
In essence, you pay a license, per developer, to download and use the IPP library to create an application. There are no royalties associated with distribution of your IPP application. That is, you do not pay any license fees to redistribute an application you build with the IPP library. The specific files you may redistribute with your application are described in the "redist.txt" file that is part of the development package.
maxim-sharabayko
Hi Paul,
Thanks for your reply!
We have rebuilt our projects with Intel IPP v 6.1, but haven't tested them on AMD processors yet. Howerer, it appears, that the possible problem we've faced will remain.
This is basically that Intel IPP library apparentely misdetects SSE4.1 or SSE4.2 instruction set on the AMD processors with SSE4A instruction set (when dispatching), which seems to crach some code parts (incorrect code execution). As I know, the previous IPP library (5.3) had an opportunity just to enable/disable optimization at all. I wonder if there is a possibility to enable/disable certain instruction sets in Intel IPP 6.1?
As a possible solution, we will detect SSE4A instruction set ourselves and initialize Intel IPP with restrictions on SSE4 instruction sets on AMD SSE4A processors, while disabling optimization at all in such cases doesn't seem good at all.
Reading some links you gave me, I've founded fuctions ippInitCpu and ippEnableCpu. I suspect these functions are to solve the problem.
Or maybe there are some alternatives to avoid misdetection of SSE4 instruction sets on AMD SSE4A?
Thank you very much!
Thomas_Jensen1
On my AMD Phenom X4, IPP 6.1.5 detects SSE3-supported CPU, and properly choses library T7.
If your code detects a SSE4-supported CPU on an AMD-system, your detection goes wrong, because AMD does not support SSE4 at this moment. They only support an AMD-only subset SSE4a. Intel compatibility only goes to SSE3.
You should also read this thread:
http://software.intel.com/en-us/forums/showthread.php?t=75428&o=a&s=lr
PaulF_IntelCorp
Can you provide a simple example that causes this crash to happen? I have access to a few up-to-date AMD machines and the tests I have run on them are consistent with the Thomas' results, the processor is detected as supporting only thru SSE3, and the appropriate library is selected. Perhaps something else is going on that is causing the crash? This is something we would like to fix, if the library is the source of the problem.
Also, as a debugging aid, compile and run the ippcpuinfo sample (in the advanced-usage samples) and see what it is reporting. The library "recommended" by this application is the one the IPP dispatcher will select.
maxim-sharabayko
Thamks Thomas, thanks Paul.
I have built and sent ippCpuInfo to our customers. Still waiting for response.
Thomas_Jensen1
Another suggestion: write code to verify which IPP library was used. Call ippiGetLibVersion() and print that.
Another idea: if 10% increase is all you get, it could be because you run on a single-core HT-enabled CPU. Running two threads on such a CPU would not give 2x performance.
maxim-sharabayko
Thanks for your advices.
It appears that the problem wasn't in ipp library misdetection. It works fine :)
Chao_Y_Intel
Thanks for letting us to know theresult. Feel free to comehere if you have any questions.
Chao
