Separable 2d convolution with nxn filter
emilio_maggio
Does anybody has a simple example of how to perform a 2d separable convolution with an nxn filter.
I do not understand welll how IPP works.
Is it better to add the border to the image and then to use FilterRow and FilterColumnone after the other with the entire image as ROI, or calculate the border on fly using ippiFilterRowBorderPipeline? In the last case how can I deal with the top and bottom border since ippiFilterColumnPipeline does not include the on fly calculation of the borders.
I thinck I miss something, I have studied the example at the end of the section in the documentation, but that one is limitated by using a 3x3 kernel.
Emilio
Intel_C_Intel
You can use ippiFilterRowBorderPipeline and ippiFilterColumnPipeline. For ippiFilterColumnPipeline you have to prepare borders manually
We prepared simple example for you, please take a look on attached source file. (border - ippBorderRepl, kernelSize - 5, anchor - 2)
Michael
Intel_C_Intel
Michael
zuliani
Hallo Michael,
Thanks for posting a general example regarding the convolution with separable filters. I am trying to modify your code so that it can be called from within Matlab (in a MEX file). There are a few things that still are not clear to me. I hope you can help me.
I do not clearly understand what this section of the code does:
/* organize dst buffer */
pTmp = (Ipp16s*)(ppDst+size.height);
for(i=0;i ppDst = pTmp;
ppSrc[i+2]=pTmp;
/* organize replicate border for ippiFilterColumnPipeline_16s_C1R */
/* top */
ppSrc[0]=ppSrc[2];
ppSrc[1]=ppSrc[2];
/* bottom */
ppSrc[i-1+4]=ppDst[size.height-1];
ppSrc[i-2+4]=ppDst[size.height-1];
I understand that you are arranging the pointers to the image borders for the replication but the whole process is not very clear. I would appreciate some more specific comments i nthe codeso that I can generalize this to any kernel size (I suspect that some coefficients like the 2 and the 4 in ppSrc[2] and ppSrc[i-2+4] are somehow related to the semisize of the filter that you using in this example but it is not clear why and how).
I also include my version of the code so that you may spot major mistakes and bugs:
#ifdef MEX_CONV2_SEP_SINGLE_USE_IPP
inline
void CheckIPPStatus(IppStatus status)
if(status != ippStsNoErr)
mexPrintf(" status = %s ", ippGetStatusString(status));
mexErrMsgTxt("IPP error");
// Adapted from:
// http://softwarecommunity.intel.com/isn/Community/en-US/forums/5482632/PostAttachment.aspx
// INTEL CORPORATION PROPRIETARY INFORMATION
// This software is supplied under the terms of a license agreement or
// nondisclosure agreement with Intel Corporation and may not be copied
// or disclosed except in accordance with the terms of that agreement.
// Copyright (c) 2005 Intel Corporation. All Rights Reserved.
// Separable 2D convolution example
void
SepConv(const Ipp32f *pSrcBuffer, Ipp32f *pDstBuffer, IppiSize *size, Ipp32f *hc, int Nc, Ipp32f *hr, int Nr)
int sizerow, sizecol, i;
int maxKernelSize = (Nc > Nr) ? Nc : Nr;
Ipp32f **ppDst, **ppSrc, *pTmp;
Ipp8u *pBufferCol, *pBufferRow;
IppStatus status;
//int xAnchor = (Nr >> 1) + 1;
int yAnchor = (Nc >> 1) + 1;
// allocate temporary dst buffer
ppDst = (Ipp32f**)ippsMalloc_8u(size->width*size->height*
sizeof(Ipp32f) + (size->height)*sizeof(Ipp32f*));
ppSrc = (Ipp32f**)ippsMalloc_8u((size->height+maxKernelSize)*
sizeof(Ipp32f*));
// size of temporary buffers
status = ippiFilterRowBorderPipelineGetBufferSize_32f_C1R(*size, maxKernelSize, &sizerow);
CheckIPPStatus(status);
status = ippiFilterColumnPipelineGetBufferSize_32f_C1R(*size, maxKernelSize, &sizecol);
//mexPrintf(" size = {%d,%d}", size->height, size->width);
// allocate temporary buffers
pBufferCol = ippsMalloc_8u(sizecol);
if (pBufferCol == NULL) mexErrMsgTxt("IPP error: failed to allocate column buffer");
pBufferRow = ippsMalloc_8u(sizerow);
if (pBufferRow == NULL) mexErrMsgTxt("IPP error: failed to allocate row buffer");
// organize dst buffer
pTmp = (Ipp32f*)(ppDst+size->height);
for(i = 0; iheight; i++, pTmp += size->width)
ppDst = pTmp;
ppSrc[i+2] = pTmp;
// organize replicate border for ippiFilterColumnPipeline_32f_C1R
// top
ppSrc[0] = ppSrc[2];
ppSrc[1] = ppSrc[2];
// bottom
ppSrc[i-1+4] = ppDst[size->height-1];
ppSrc[i-2+4] = ppDst[size->height-1];
// perform the convolution
mexPrintf(" pSrcBuffer = {%f, %f, %f, %f}", pSrcBuffer[0], pSrcBuffer[1], pSrcBuffer[2], pSrcBuffer[3]);
mexPrintf(" hc = {%f, %f, %f, %f}", hc[0], hc[1], hc[2], hc[3]);
mexPrintf(" size = {%d, %d}", size->height, size->width);
mexPrintf(" sizerow = %d, sizecol = %d", sizerow, sizecol);
status = ippiFilterRowBorderPipeline_32f_C1R((
const Ipp32f*) pSrcBuffer, size->width*sizeof(Ipp32f), ppDst,
*size, hc, Nc, yAnchor, ippBorderRepl, 0, pBufferRow);
status = ippiFilterColumnPipeline_32f_C1R((
const Ipp32f **)ppSrc, pDstBuffer, size->width*sizeof(Ipp32f), *size,
hr, Nr, pBufferCol);
ippsF ree(ppSrc);
ippsFree(ppDst);
ippsFree(pBufferCol);
ippsFree(pBufferRow);
#endif
Thanks in advance for your help,
Marco
zuliani
This is the version of the code that I would expect to generalize the one originally posted by Michael. In particular I modified the section for the organization of the buffers as follows:
// (the offset takes care of the double pointer structure)
ppDst = pTmp;
ppSrc[i+yAnchor] = pTmp;
for(i = 0; i < yAnchor; i++)
// top
ppSrc = ppSrc[yAnchor];
// bottom
ppSrc[i + size->height] = ppSrc[size->height-1];
Unfortunately performing the second convolution (within the MEX file, ippiFilterColumnPipeline_32f_C1R) the status returned by IPP says Null pointer error
I am reposting the original code for your convenience. Note that hxc and hr are the convolution kernels whose lenght is respectively Nc and Nr.
#ifdef
inline
mexPrintf(
mexErrMsgTxt(
"IPP error");
// Adapted from:
void
IppStatus status;
sizeof(Ipp32f*));
// organize dst buffer (the offset takes care of the double pointer structure)
ppDst = pTmp;
// top
// bottom
// perform the convolutions
const Ipp32f*) pSrcBuffer, size->width*sizeof(Ipp32f), ppDst, *size, hc, Nc, yAnchor, ippBorderRepl, 0, pBufferRow);
const Ipp32f **)ppSrc, pDstBuffer, size->width*sizeof(Ipp32f), *size, hr, Nr, pBufferCol);
ippsFree(ppSrc);
ippsFree(ppDst);
#endif
The above function is called as:
// in version for the different byte ordering between Matlab and IPP
IppiSize size;
size.height = width;
size.width = height;
SepConv((Ipp32f *)f, (Ipp32f *)g, &size, (Ipp32f *)hc, Nc, (Ipp32f *)hr, Nr);
Again thanks in advance for any useful insight,
Marco
Intel_C_Intel
Example 9-4 (p 9-55 of IPP manual vol2, Jan 2007) described how to use ippiFilterRow/ColumnBorderPipeline functions to calculate the separable convolution without the intermediate buffer for the whole image.
The ring buffer (the double pointer) for convolved rows is used there. You should befine the border type for row convolution because there is no data outside the image. But border rows for column convolution are formed manually, so you need not extra argument for them.
Eg for the 3x3 convolution with replicate border you need to replicate the pointer to the first convolved row.
Alexander
zuliani
Dear Alexander,
thanks for your prompt response. I must say that I found the Example 9-4 extremely criptic (30 lines of dense code without a single comment...). However I came up with a routine that seems to achive the task. Note that there are a bunch of tricks to handle kernel sizes that can be even or odd. The flipping of the kernel is meant to adapt my routine with the conv2 routine of Matlab (and for the same reasonone might notice "inversion" between row and columns, since Matlabuses column-major ordering of the data, as in Fortran).
I hope that this can be of some help. I would appreciate any help from the community as far asbugs/improvments are concerned.
#ifdef
inline
mexPrintf(
mexErrMsgTxt(
"IPP error");
// Adapted by Marco Zuliani ([email protected]) from:
// or disclosed except in aNcssordance with the terms of that agreement.
void
int sizerow, sizecol, i, j;
// flip the kernels and align the memory to please IPP
Ipp32f *hc_flipped = (Ipp32f *)ippsMalloc_32f(Nc *
sizeof(float));
Ipp32f *hr_flipped = (Ipp32f *)ippsMalloc_32f(Nr *
sizeof(float));
for(i = 0; i < Nc; i++) hc_flipped = hc[Nc-i-1];
for(j = 0; j < Nr; j++) hr_flipped = hr[Nr- j-1];
// compute the kernel semisizes
int Ncss = Nc >> 1;
int Nrss = Nr >> 1;
// compute the kernel offsets (0 -> odd, 1 -> even)
int co = 1-(Nc%2);
int ro = 1-(Nr%2);
sizeof(Ipp32f)+(size->height)*sizeof(Ipp32f*));
ppSrc = (Ipp32f**)ippsMalloc_8u((size->height+Nc)*
sizeof(Ipp32f*));
ippiFilterRowBorderPipelineGetBufferSize_32f_C1R(*size, Nc, &sizerow);
ippiFilterColumnPipelineGetBufferSize_32f_C1R(*size, Nr, &sizecol);
pTmp = (Ipp32f*)(ppDst + size->height);
for(i = 0; i < size->height; i++, pTmp += size->width)
ppDst = pTmp;
ppSrc[i+Nrss-ro] = pTmp;
for(j = 0; j < Nrss; j++)
// top
ppSrc = ppSrc[Nrss-ro];
// bottom
ppSrc[i-j+Nr-2] = ppDst[size->height-1];
// perform the actual convolutions
*size, hc_flipped, Nc, Ncss-co, ippBorderConst, 0, pBufferRow);
const Ipp32f**)ppSrc, pDstBuffer, size->width*sizeof(Ipp32f), *size,
hr_flipped, Nr, pBufferCol);
// release some memory
ippsFree(hc_flipped);
ippsFree(hr_flipped);
ippsFree(ppSrc);
ippsFree(ppDst);
#endif
jschamus
Copyright(C) 2004-2009, Riverain Medical Group LLC. All Rights Reserved.
This is UNPUBLISHED PROPRIETARY SOURCE CODE of Riverain Medical Group, LLC.
The contents of this file may not be disclosed to third parties, copied or
duplicated in any form, in whole or in part, for use or transmittal, without
the prior written permission of Riverain Medical Group LLC
* file IppSepFilter.cpp
* brief Implementation of Separable Filter with IPP
* author J. Schamus, [email protected]
# pragma once
# include "Image.h"
static inline IppStatus ippSepFilter(
const Ipp32f* pSrc, // Sourse Image
const int srcStep, // Source step
Ipp32f* pDst, // Destination Image
const int dstStep, // Destination step
const IppiSize roiSize, // Source/Destination size
const Ipp32f* hc, // Column filter
const int Nc, // Column filter size
const Ipp32f* hr, // Row filter
const int Nr, // Row filter size
const PadType& padType = CONSTANT, // Padding type
const Ipp32f val = 0.0f ) // Value to use with CONSTANT padding
IppStatus sts;
int sizerow, sizecol;
Ipp32f **ppDst, **ppSrc, *pTmp = NULL;
Ipp8u *pBufferCol = NULL, *pBufferRow = NULL;
int Ncss = Nc >> 1;
int Nrss = Nr >> 1;
int co = 1 - ( Nc % 2 );
int ro = 1 - ( Nr % 2 );
int tmpStep;
pTmp = ippiMalloc_32f_C1( roiSize.width, roiSize.height + (Ncss * 2), &tmpStep );
if( !pTmp ) return ippStsMemAllocErr;
int tmpw = tmpStep / sizeof(Ipp32f);
IppiSize tmpSize;
tmpSize.height = roiSize.height + (Ncss * 2) - co; tmpSize.width = roiSize.width;
ippiSet_32f_C1R( 0.0f, pTmp, tmpStep, tmpSize );
ppDst = new Ipp32f*[roiSize.height];
ppSrc = new Ipp32f*[roiSize.height + (Nrss * 2) - co];
if( sts = ippiFilterRowBorderPipelineGetBufferSize_32f_C1R( roiSize, Nc, &sizerow) )
return sts;
if( sts = ippiFilterColumnPipelineGetBufferSize_32f_C1R( roiSize, Nr, &sizecol) )
return sts;
pBufferCol = ippsMalloc_8u( sizecol );
if( !pBufferCol ) return ippStsMemAllocErr;
pBufferRow = ippsMalloc_8u( sizerow );
if( !pBufferRow ) return ippStsMemAllocErr;
Nrss -= ro;
Ncss -= co;
for( int ii=0,jj=Ncss;ii {
ppDst[ii] = pTmp + jj * tmpw;
ppSrc[jj] = pTmp + jj * tmpw;
IppiBorderType borderType;
switch( padType )
case CONSTANT:
for( int ii=0,jj=roiSize.height+Ncss;ii {
ppSrc[ii] = pTmp + ii * tmpw;
if( val )
ippsSet_32f( val, ppSrc[ii], roiSize.width );
ippsSet_32f( val, ppSrc[jj], roiSize.width );
else
ippsZero_32f( ppSrc[ii], roiSize.width );
ippsZero_32f( ppSrc[jj], roiSize.width );
if( co )
ppSrc[roiSize.height+(Ncss*2)] = pTmp + (roiSize.height+(Ncss*2)) * tmpw;
ippsSet_32f( val, ppSrc[roiSize.height+(Ncss*2)], roiSize.width );
borderType = ippBorderConst;
break;
case REPLICATE:
ppSrc[ii] = ppSrc[Ncss];
ppSrc[jj] = ppSrc[roiSize.height+Ncss-1];
if( co )
ppSrc[roiSize.height+(Ncss*2)] = ppSrc[roiSize.height+Ncss-1];
borderType = ippBorderRepl;
break;
case SYMMETRIC:
ppSrc[ii] = ppSrc[(Ncss*2)-ii-1];
ppSrc[jj] = ppSrc[roiSize.height+Ncss-ii-1];
if( co )
ppSrc[roiSize.height+(Ncss*2)] = ppSrc[roiSize.height-1];
borderType = ippBorderMirrorR;
break;
case CIRCULAR:
ppSrc[ii] = ppSrc[roiSize.height+ii];
ppSrc[jj] = ppSrc[ii+Ncss];
if( co )
ppSrc[roiSize.height+(Ncss*2)] = ppSrc[Ncss*2];
borderType = ippBorderWrap;
break;
default:
return ippStsPaddingSchemeErr; // ippStsBorderErr missing from ippdefs.h
if( sts = ippiFilterRowBorderPipeline_32f_C1R((const Ipp32f*) pSrc, srcStep,
ppDst, roiSize, hr, Nr, Nrss, borderType, val, pBufferRow) )
return sts;
if( sts = ippiFilterColumnPipeline_32f_C1R((const Ipp32f**)ppSrc, pDst, dstStep,
roiSize, hc, Nc, pBufferCol) )
return sts;
ippsFree(pTmp);
delete []ppSrc;
delete []ppDst;
return sts;
No Guarntees with this, but it has been tested with both even and odd sized kernals and for all padding types.
Enjoy,
Jay Schamus
Vladimir_Dudnik
Hi Jay,
thanks for sharing of your expertise with IPP developers community. Although the copyright notice of your code may look misleading. Is it possible to disclosure this code?
Vladimir
jschamus
Hi Jay,
Vladimir
Sure fine. Just acknowledge the source.
zuliani
Hi Jay
Thanks alot for sharing your improved version of the convolution code. I was wondering if you can check a couple of things:
1] Should the line
read instead as:
ppSrc = new Ipp32f*[roiSize.height + (Ncss * 2) - co];
so that the loop:
for( int ii=0,jj=roiSize.height+Ncss;ii{
will not exceed the boundaries?
2] Should the lines:
return sts;
return sts;
be instead:
if( sts = ippiFilterRowBorderPipelineGetBufferSize_32f_C1R( roiSize, Nr, &sizerow) )
return sts;
if( sts = ippiFilterColumnPipelineGetBufferSize_32f_C1R( roiSize, Nc, &sizecol) )
return sts;
i.e. with Nr and Nc swapped?
Marco
jschamus
Hi Jay
1] Should the line
read instead as:
so that the loop:
return sts;
return sts;
be instead:
return sts;
return sts;
Marco
Marco,
sorry to take so long to get back, but I've been busy. Here is the corrected code for this (can't use new and delete ro it will crash once every ~1000 times you run it ). Also, I included a version that runs the filter in reverse order (CR vs. RC), for those that need to match MatLab. Note the Copyright is there but it means that if you use this code please acknowledge the source. And also, one of our guys who is experimenting with 64-bit under Windows 2008 gets a crash every time at the call to ippiFilterRowBorderPipelineGetBufferSize_32f_C1R when builds this as a 64-bit DLL.
[cpp]/*********************************************************************************
# pragma once
# include
// Row major version
static inline IppStatus IppSepFilterRC(
const int& dstStep, // Destination step
const Ipp32f* pSrc, // Source Image
const int& srcStep, // Source step
const IppiSize& roiSize, // Source/Destination size
const int& Nr, // Row filter size
const int& Nc, // Column filter size
const Ipp32f& val = 0.0f ) // Value to use with CONSTANT padding
TRY_AUTO
IppStatus sts;
Ipp32f *pTmp = NULL;
Ipp32f *pTmpLocal = NULL;
Ipp32f *hc_flipped = (Ipp32f *)ippsMalloc_32f( Nc );
Ipp32f *hr_flipped = (Ipp32f *)ippsMalloc_32f( Nr );
ippsFlip_32f((const Ipp32f*)hc, hc_flipped, Nc );
ippsFlip_32f((const Ipp32f*)hr, hr_flipped, Nr );
int Ncss = Nc >> 1;
int Nrss = Nr >> 1;
int tmpStep;
int tmpw;
// The IPP filter functions seem to need 1 more row allocated
// than is obvious or they sometimes crash.
int tmpHeight = roiSize.height+Nc+1;
int tmpWidth = roiSize.width;
if( !( pTmpLocal = ippiMalloc_32f_C1( roiSize.width, roiSize.height + Nc + 1, &tmpStep ) ) )
throw exception( "nIppSepFilterRC, mem-alloc error. " );
pTmp = pTmpLocal;
Ipp32f **ppSrc, **ppDst;
ppSrc = (Ipp32f**) ippsMalloc_32f( roiSize.height + Nc + 1 );
ppDst = (Ipp32f**) ippsMalloc_32f( roiSize.height );
if( padType == CONSTANT )
IppiSize tmpSize;
tmpSize.height = roiSize.height + Nc + 1;
ippiSet_32f_C1R( val, pTmp, tmpStep, tmpSize );
throw exception( "nIppSepFilterRC, ipp-row-mem-size error. ");
throw exception( "nIppSepFilterRC, ipp-col-mem-size error. ");
if( !( pBufferCol = ippsMalloc_8u( sizecol ) ) )
throw exception( "nIppSepFilterRC, ipp-col-temp mem-alloc error. ");
if( !( pBufferRow = ippsMalloc_8u( sizerow ) ) )
throw exception( "nIppSepFilterRC, ipp-row-temp mem-alloc error. ");
Nrss -= ro;
Ncss -= co;
for( int ii=0,jj=Ncss;ii<< "IPP Error: " << ippGetStatusString( sts ) << endl;
throw exception( "nIppSepFilterRC, ipp-row-filter error. ");
return sts;
if( sts = ippiFilterColumnPipeline_32f_C1R( (const Ipp32f**)ppSrc, pDst, dstStep,
roiSize, hc_flipped, Nc, pBufferCol) )
cout << "IPP Error: " << ippGetStatusString( sts ) << endl;
throw exception( "nIppSepFilterRC, ipp-column-filter error. ");
return sts;
if( ppSrc ) { ippsFree(ppSrc); ppSrc = NULL; }
if( ppDst ) { ippsFree(ppDst); ppDst = NULL; }
if( pTmpLocal ) { ippiFree(pTmpLocal); pTmpLocal = NULL; }
if( pBufferCol ) { ippsFree(pBufferCol); pBufferCol = NULL; }
if( pBufferRow ) { ippsFree(pBufferRow); pBufferRow = NULL; }
if( hr_flipped ) { ippsFree(hr_flipped); hr_flipped = NULL; }
if( hc_flipped ) { ippsFree(hc_flipped); hc_flipped = NULL; }
return sts;
CATCH_AUTO
// Column major version
static inline IppStatus IppSepFilterCR(
TRY_AUTO
IppStatus sts;
Ipp32f *pTmp = NULL, *pPad = NULL;
int Ncss = Nc >> 1;
int Nrss = Nr >> 1;
int tmpStep, padStep;
IppiSize tmpSize;
tmpSize.width = roiSize.width; tmpSize.height = roiSize.height + Nc + 1;
if( !( pTmp = ippiMalloc_32f_C1( tmpSize.width, tmpSize.height, &tmpStep ) ) )
throw exception( "nIppSepFilterCR mem-alloc error." );
int srcw = srcStep / sizeof(Ipp32f);
int dstw = dstStep / sizeof(Ipp32f);
int padw;
IppiSize padSize;
// Only need pad space for CONSTANT
if( !( pPad = ippiMalloc_32f_C1( roiSize.width, (Ncss*2) - co, &padStep ) ) )
padw = padStep / sizeof(Ipp32f);
padSize.height = (Ncss*2) - co; padSize.width = roiSize.width;
ippiSet_32f_C1R( val, pPad, padStep, padSize );
throw exception( "nIppSepFilterCR, ipp-row-mem-size error. ");
throw exception( "nIppSepFilterCR, ipp-col-mem-alloc error. ");
throw exception( "nIppSepFilterCR, ipp-row-mem-alloc error. ");
Nrss -= ro;
Ncss -= co;
for( int ii = 0, jj = Ncss; ii < roiSize.height; ++ii, ++jj )
ppDst[ii] = pDst + ii * dstw;
ppSrc[jj] = (Ipp32f *)pSrc + ii * srcw;
switch( padType )
case CONSTANT:
for( int ii=0,jj=roiSize.height+Ncss;ii<< "IPP Error: " << ippGetStatusString( sts ) << endl;
throw exception( "nIppSepFilterCR col-filter error." );
return sts;
if( sts = ippiFilterRowBorderPipeline_32f_C1R( (const Ipp32f*)pTmp, tmpStep,
ppDst, roiSize, hr_flipped, Nr, Nrss, borderType, val, pBufferRow) )
throw exception( "nIppSepFilterCR row-filter error." );
return sts;
if( pTmp ) { ippiFree(pTmp); pTmp = NULL; }
if( pPad ) { ippsFree(pPad); pPad = NULL; };
if( pBufferCol ) { ippsFree(pBufferCol); pBufferCol = NULL; };
if( pBufferRow ) { ippsFree(pBufferRow); pBufferRow = NULL; };
if( hr_flipped ) { ippsFree(hr_flipped); hr_flipped = NULL; };
if( hc_flipped ) { ippsFree(hc_flipped); hc_flipped = NULL; };
return sts;
CATCH_AUTO
[/cpp]
jschamus
Let me repost the Column major version. I see the code insertion thnigy still has problems. :-(
[cpp]//
	TRY_AUTO
		IppStatus sts;
		int Ncss = Nc >> 1;
		int Nrss = Nr >> 1;
		IppiSize tmpSize;
		int padw;
		IppiSize padSize;
		Nrss -= ro;
		Ncss -= co;
		switch( padType )
		case CONSTANT:
			return sts;
			return sts;
		return sts;
	CATCH_AUTO
[/cpp]
jschamus
Holy Crap! The code looks okay in the editor window, then it gets cut up when it gets posted. Trying again!
[cpp]//
	TRY_AUTO
		IppStatus sts;
		int Ncss = Nc >> 1;
		int Nrss = Nr >> 1;
		IppiSize tmpSize;
		int padw;
		IppiSize padSize;
		Nrss -= ro;
		Ncss -= co;
		switch( padType )
		case CONSTANT:
			for( int ii=0,jj=roiSize.height+Ncss;ii,++jj )
ppSrc[ii] = pPad + ii * padw;
ppSrc[jj] = pPad + (ii + Ncss) * padw;
if( co )
ppSrc[roiSize.height+(Ncss*2)] = pPad + (Ncss*2) * srcw;
break;
case REPLICATE:
if( co )
break;
case SYMMETRIC:
if( co )
break;
case CIRCULAR:
if( co )
break;
default:
if( sts = ippiFilterColumnPipeline_32f_C1R( (const Ipp32f**)ppSrc, pTmp, tmpStep,
//cout << "IPP Error: " << ippGetStatusString( sts ) << endl; throw exception( "nIppSepFilterCR col-filter error." ); return sts; } if( sts = ippiFilterRowBorderPipeline_32f_C1R( (const Ipp32f*)pTmp, tmpStep, ppDst, roiSize, hr_flipped, Nr, Nrss, borderType, val, pBufferRow) ) { //cout << "IPP Error: " << ippGetStatusString( sts ) << endl; throw exception( "nIppSepFilterCR row-filter error." ); return sts; } if( ppSrc ) { ippsFree(ppSrc); ppSrc = NULL; } if( ppDst ) { ippsFree(ppDst); ppDst = NULL; } if( pTmp ) { ippiFree(pTmp); pTmp = NULL; } if( pPad ) { ippsFree(pPad); pPad = NULL; }; if( pBufferCol ) { ippsFree(pBufferCol); pBufferCol = NULL; }; if( pBufferRow ) { ippsFree(pBufferRow); pBufferRow = NULL; }; if( hr_flipped ) { ippsFree(hr_flipped); hr_flipped = NULL; }; if( hc_flipped ) { ippsFree(hc_flipped); hc_flipped = NULL; }; return sts; } CATCH_AUTO } [/cpp]
jschamus
Quoting - jschamus
[cpp]//
TRY_AUTO
IppStatus sts;
int Ncss = Nc >> 1;
int Nrss = Nr >> 1;
IppiSize tmpSize;
int padw;
IppiSize padSize;
Nrss -= ro;
Ncss -= co;
switch( padType )
case CONSTANT:
if( co )
break;
case REPLICATE:
if( co )
break;
case SYMMETRIC:
if( co )
break;
case CIRCULAR:
if( co )
break;
default:
return sts;
return sts;
return sts;
CATCH_AUTO
[/cpp]
A small correction to the correction to correction. The section of the code where it messed up should read:
switch( padType )
case CONSTANT:
jschamus
On closer examination I see that the RC function got chopped up too. Sigh!
[cpp]// Row major version
	TRY_AUTO
		IppStatus sts;
		int Ncss = Nc >> 1;
		int Nrss = Nr >> 1;
		int tmpStep;
		int tmpw;
		pTmp = pTmpLocal;
			IppiSize tmpSize;
		Nrss -= ro;
		Ncss -= co;
switch( padType )
case CONSTANT:
if( co )
break;
case REPLICATE:
if( co )
break;
case SYMMETRIC:
if( co )
break;
case CIRCULAR:
if( co )
break;
default:
if( sts = ippiFilterRowBorderPipeline_32f_C1R( (const Ipp32f*)pSrc, srcStep,
cout << "IPP Error: " << ippGetStatusString( sts ) << endl; throw exception( "nIppSepFilterRC, ipp-row-filter error. "); return sts; } if( sts = ippiFilterColumnPipeline_32f_C1R( (const Ipp32f**)ppSrc, pDst, dstStep, roiSize, hc_flipped, Nc, pBufferCol) ) { cout << "IPP Error: " << ippGetStatusString( sts ) << endl; throw exception( "nIppSepFilterRC, ipp-column-filter error. "); return sts; } if( ppSrc ) { ippsFree(ppSrc); ppSrc = NULL; } if( ppDst ) { ippsFree(ppDst); ppDst = NULL; } if( pTmpLocal ) { ippiFree(pTmpLocal); pTmpLocal = NULL; } if( pBufferCol ) { ippsFree(pBufferCol); pBufferCol = NULL; } if( pBufferRow ) { ippsFree(pBufferRow); pBufferRow = NULL; } if( hr_flipped ) { ippsFree(hr_flipped); hr_flipped = NULL; } if( hc_flipped ) { ippsFree(hc_flipped); hc_flipped = NULL; } return sts; } CATCH_AUTO } [/cpp]
Vladimir_Dudnik
thanks for updating your sample of IPP based convolution. I would recommend to use attachment for big code chunks instead of inserting code into post as it may cause truncation.
If you can provide us a sample which cause crach in 64-bit mode we will investigate the reason (you also may quickly check if issue is related to optimized code by dispatching a generic, PX version of IPP library)
Vladimir
Piotr_Wendykier
What is wrong with the following code? It crashes only when I call IppRowFilter multiple times.
static inline IppStatus IppRowFilter(
 const IppiSize dstSize,      // Destination size
 const int  Nr)        // Row filter size
 IppStatus sts;
 int sizerow;
 Ipp8u *pBufferRow = NULL;
 IppiSize srcSize = { dstSize.width + Nr - 1, dstSize.height };
 // flip the kernel and align the memory to please IPP
 Ipp32f *hr_flipped = (Ipp32f*)ippsMalloc_32f(Nr*sizeof(Ipp32f));
 ippsFlip_32f((const Ipp32f*)hr, hr_flipped, Nr);
 Ipp32f **ppDst = (Ipp32f**)ippsMalloc_32f(dstSize.height*sizeof(Ipp32f));
 if (sts = ippiFilterRowBorderPipelineGetBufferSize_32f_C1R(srcSize, Nr, &sizerow)) { goto cleanup; }
 if (!(pBufferRow = ippsMalloc_8u(sizerow))) { sts = ippStsNoMemErr; goto cleanup; }
 for (int ii = 0; ii < dstSize.height; ii++) {
  ppDst[ii] = pDst + ii * (dstStep / sizeof(Ipp32f));
 if (sts = ippiFilterRowBorderPipeline_32f_C1R((const Ipp32f*)pSrc, srcStep, ppDst, srcSize, hr_flipped, Nr, 0, ippBorderRepl, 0, pBufferRow))
  goto cleanup;
cleanup:
 if (ppDst)   { ippsFree(ppDst); ppDst = NULL; }
 if (pBufferRow)  { ippsFree(pBufferRow);  pBufferRow = NULL; }
 if (hr_flipped)  { ippsFree(hr_flipped); hr_flipped = NULL; }
 return sts;
Alexander_U_Intel
I can't reproduce crash with your code.
Could you provide your version of IPP and values of dstSize, srcStep, dstSize, filter and filter size?
BR,
Alexander
Ying_H_Intel
Hi Piotr,
The code looks ok, just one small problem about
21 Ipp32f **ppDst = (Ipp32f**)ippsMalloc_32f(dstSize.height*sizeof(Ipp32f));
and ppDst[ii] = pDst + ii * (dstStep / sizeof(Ipp32f));
Here ppDst is double pointers.
if in 32bit application, it is ok as sizeof(Ipp32f)=4 and sizeof(Ipp32f *) =4.
but when in 64bit application. sizeof (IPP32f*)=8, not 4. so for safety,it is better to change
 Ipp32f **ppDst = (Ipp32f**)ippsMalloc_32f(dstSize.height*sizeof(Ipp32f*));
Ying
Piotr_Wendykier
I'm using IPP 9.0.1 for Windows. Here is the function that calls IppRowFilter:
mbool ImageRowFilter(Image * const pres, const Image img, const float * kernel, const mint kernel_length)
        const int w = (int)ImageWidth(img);
	const int h = (int)ImageHeight(img);
	const int channels = (int)ImageChannels(img);
	IppiSize srcSize = { w, h };
	int srcStep = srcSize.width * sizeof(Ipp32f);
	IppiSize dstSize = { (int)(w - kernel_length + 1), (int)h };
	int	dstStep = dstSize.width * sizeof(Ipp32f);
	Ipp32f* pSrc = NULL, *pDst = NULL;
	IppStatus stat;
	*pres = Image_newAllocated_size(img, dstSize.width, dstSize.height, channels);
	if (*pres == NOT_AN_IMAGE) {
		return FALSE;
	for (mint c = 0; c < channels; c++) {
		pSrc = ImageSliceElemPointer(img, raw_t_real32, 0, 0, 0, c);
		pDst = ImageSliceElemPointer(*pres, raw_t_real32, 0, 0, 0, c);
		stat = IppRowFilter(pDst, dstStep, pSrc, srcStep, dstSize, kernel, kernel_length);
		if (stat != ippStsNoErr) {
 			goto cleanup;
cleanup:
		Image_delete(pres);
		return FALSE;
	return TRUE;
It uses my data structures so you will not be able to compile it, but it shows how I set srcSize, srcStep, dstSize, and dstStep.
I have noticed that it does not crash when I increase the height of the output image by 1, i.e.:
*pres = Image_newAllocated_size(img, dstSize.width, dstSize.height + 1, channels);
I'm testing this code using an RGB image (width = 150, height = 116) and the following kernel: {0.0216149, 0.0439554, 0.0778778, 0.118718, 0.153857, 0.167953, 0.153857, 0.118718, 0.0778778, 0.0439554, 0.0216149}.
