Simple question
jdm2104
I am using an FIRfunction out of the Intel Performance Primitives (IPP)library but have been having problems whenrunning a release version of my application onanother machine (missing .dlls).How can I make sure my application runs? I know I need to statically link to the dll filesbut as I am new to programming I'm not sure how. I'm using the MSVC 6 compiler.
Is this something you do in the project settings?
David
Intel_C_Intel
You need to add the static .lib file to the project. Under "project setting" dialog, click "Link", select "Input" from "Category", add the IPP static lib to "Object/library modules" field.
At the same time, I'll transfer you to the IPP forum.
Jennifer
