Some question about jpeg2000 ecoding/decoding
gluck
I want to make decision about to use or not the IPP. And I have some questions:
1. Is it possible to decode arbitrary requiredrectangle from jpeg2000 without coping memory (without extracting this required rectangle from the image)?
2. Is it possibleto decode rectangle (as above), but with determined quality (with lessquality)?
3. Am I able toworkwith channels separarely withoutsurplus memory usage (and without surplus time usage) ?
Vladimir_Dudnik
Please see my comments below
VD:IPP functionality is not limited byhigh-level sample code provided with IPP (like JPEG2000 codec). You mayfind it useful to applyIPP functions for some tasks in your application separately even if functionality of some particular IPP code sample does not cover your needs.
VD: You probably mean without decoding the whole image first and than copying required rectangle? This functionality is not supported yet in IPP JPEG2000 codec.
VD: this is not supported in current version but we plan to provide such functionality in IPP JPEG2000 codecs in future.
VD: assuming you mean JPEG2000 codec, the answer isno. You can't decode single channel from JPEG2000 stream.
Vladimir
Calle
I am also trying to make a decision whether or not to use IPP for Jpeg2000 decoding.
Is the response by Vladimir (more specifically point 1 and 2) still valid for the latest release of IPP?
If so, can anyone give a reasonable guesstimate for when this functionality will be made available? Is the functionality planned for a scheduled release?
Vladimir_Dudnik
this functionality was not scheduled for the nearest IPP 6.1 release. Please submit your feature request through Intel Premier Support to get it reviewed at the next version planning stage.
Vladimir
