6825 Discussions
Suspected Bug: ippsGFpECSignDSA generates small signatures when AVX-512F is enabled
Crypto_P
The following code fails to produce a valid signature when AVX-512F is enabled but works when it is disabled:
Ipp64u mask = 0;
        IppStatus ret = ippcpGetCpuFeatures(&mask);
        //ret = ippcpSetCpuFeatures(mask^ippCPUID_AVX512IFMA); //when this step is uncommented the below code verifies
        int buffer_size = 0;
        ippsGFpGetSize(256, &buffer_size);
        IppsGFpState* galois_field = (IppsGFpState*) (new Ipp8u [buffer_size]);
        ippsGFpInitFixed(256, ippsGFpMethod_p256r1(), galois_field);
        buffer_size = 0;
        ippsGFpECGetSize(galois_field, &buffer_size);
        IppsGFpECState* elliptic_curve = (IppsGFpECState*) (new Ipp8u [buffer_size]);
        ippsGFpECInitStd256r1(galois_field, elliptic_curve);
        buffer_size = 0;
        ippsGFpECScratchBufferSize( 1, elliptic_curve, &buffer_size);
        Ipp8u* scratch_buffer = new Ipp8u [buffer_size];
        IppECResult res  = ippECInvalidSignature;
        ippsGFpECVerify( &res, elliptic_curve,  scratch_buffer);
        int big_num_size = 0;
        auto word_size = BITSIZE_WORD(static_cast<int>(80*8));
        ippsBigNumGetSize(word_size, &big_num_size);
        IppsBigNumState* secret_key = (IppsBigNumState*)(new Ipp8u [big_num_size]);
        IppsBigNumState* eph_secret_key = (IppsBigNumState*)(new Ipp8u [big_num_size]);
        IppsBigNumState* sig_y = (IppsBigNumState*)(new Ipp8u [big_num_size]);
        IppsBigNumState* sig_x = (IppsBigNumState*)(new Ipp8u [big_num_size]);
        IppsBigNumState* message = (IppsBigNumState*)(new Ipp8u [big_num_size]);
        ippsBigNumInit(word_size, secret_key);
        ippsBigNumInit(word_size, message);
        ippsBigNumInit(word_size, eph_secret_key);
        ippsBigNumInit(word_size, sig_y);
        ippsBigNumInit(word_size, sig_x);
        ippsGFpECPrivateKey(secret_key, elliptic_curve, (IppBitSupplier) /*prng*/, NULL);
        ippsGFpECPrivateKey(eph_secret_key, elliptic_curve, (IppBitSupplier) /*prng*/, NULL);
        buffer_size = 0;
        ippsGFpECScratchBufferSize(1, elliptic_curve, &buffer_size);
        delete [] (Ipp8u*)scratch_buffer;
        buffer_size = 0;
        ippsGFpECPointGetSize(elliptic_curve, &buffer_size);
        IppsGFpECPoint* public_key = (IppsGFpECPoint*)(new Ipp8u[buffer_size]);
        ippsGFpECPointInit(NULL, NULL, public_key, elliptic_curve);
        ippsGFpECPublicKey(secret_key, public_key, elliptic_curve, scratch_buffer);
        //assuming msg_data is within the order of the curve
        ippsSet_BN(IppsBigNumPOS, /*msg_data_size*/, /*msg_data*/, message);
        buffer_size = 0;
        ippsGFpECSignDSA(message, secret_key, eph_secret_key, sig_x, sig_y, elliptic_curve, scratch_buffer);
        IppECResult pResult = ippECInvalidSignature;
        ippsGFpECVerifyDSA(message, public_key, sig_x, sig_y, &pResult, elliptic_curve, scratch_buffer);
        if(pResult == ippECValid)
            //pResult ends up being invalid
Im using the following version of ippcp: ippCP AVX-512F/CD/BW/DQ/VL/SHA/VBMI/VBMI2/IFMA/GFNI/VAES/VCLMUL (k1) 2021.7.0 (11.5 ) (-)
VarshaS_Intel
Could you please let us know your OS details you are using?
Could you please provide us with the complete sample reproducer code along with the complete steps you had followed to reproducer your issue at our end?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Cold you please provide us with an update on your issue?
Thanks & Regards,
Varsha
