Transparency
greekgoddj
Principiante
1.205 Vistas
I have been looking through the IPP Image processing manual and don't seem to find a function for transparency. I thoughts this was quite a common routine in image processing and that I might find it in the IPP. Is it called something else? ..I basically want to copy one image over another, specifying a particular colour to be treated as the transparent colour.
Any ideas?
Aristotel
Message Edited by [email protected] on 07-21-2005 03:32 AM
0 kudos
2 Respuestas
pascal_bamford
Principiante
1.205 Vistas
Aristotel,
The term you are after is 'alpha'. This is the weighting factor used to combine images with transparent effect.
IPP has extensive support for 4 channel images (RGBA where A is alpha). Perhaps start by looking at the functions in section 5 of ippiman.pdf under 'Alpha Composition'.
Pascal.
greekgoddj
Principiante
1.205 Vistas
Thanks for that information Pascal!
Aristotel
Responder
