UMC MP2/H264 decode information question
pvonkaenel
New Contributor III
I have been using the MP2/H264 decoders in the UMC library to perform decoded image analysis. I recently discovered that the UMC::VideoData.m_picStructure element always seems to be set to PS_FRAME even when the video is interlaced. I was under the impression that PS_FRAME should only happen for progressive video, and that interlaced frames would be either PS_TOP_FIELD_FIRST or PS_BOTTOM_FIELD_FIRST. Is this correct? Is there some other way I can determine if the video is interlaced/progressive, and if it is interlaced, which field is first?
Peter
Chao_Y_Intel
Hi Peter,
You are right. This looks a problem for the Codec. No any decoder sets this variables and it holds the initial value always. We tracked this problem for future fix.
Chao
pvonkaenel
New Contributor III
Quoting - Chao Y (Intel)
Hi Peter,
Chao
Hi Chao and thanks for the reply,
Is there something I probe short term to determine the progressive/interlace of a bitstream, and if interlaced, which field comes first?
Peter
