Hi
I have the following Pixel Format 'UYVY'4:2:2 Compression interleaved. In the document it is described as the following
Four 8-bit Unsigned Components are packed into one 32-bit little-endian word.
Byte_3:Y'1 Byte_2:Cr0 Byte_1:Y'0 Byte_0:Cb0.
I want to convert this into YUV420 Planar or somethingI can use with mpeg2 compression.
What functions is there availablein IPP to achieve this as it is very confusing.
Jurie
Do you have any problem to look at IPP documentation or header files?
I think something from the follwong should do what you are looking for:
Vladimir
[cpp]/* ////////////////////////////////////////////////////////////////////////////
// Name: ippiYUToYU422_8u_C2P2R, ippiUYToYU422_8u_C2P2R
// Purpose: Converts 2-channel YUY2,UYVY images to the 2-plane NV12 image
// Return:
// ippStsNoErr Ok
// ippStsNullPtrErr One of the pointers is NULL
// ippStsSizeErr roiSize has a field value less than 2
// Parameters:
// pDstY Pointer to the destination image Y plane.
// dstYStep The step through the destination image Y plane.
// pDstCbCr Pointer to the destination image CbCr plane.
// dstCbCrStep The step through the destination image CbCr plane.
// pSrc Pointer to the source image
// srcStep Step through the source image
// roiSize Size of the ROI, should be multiple of 2.
// Notes:
// for ippiYUToYU422_8u_C2P2R sequence of bytes in the source image is( YUY2 ):
// Y0U0Y1V0,Y2U1Y3V1,...
// for ippiUYToYU422_8u_C2P2R sequence of bytes in the destination image is( UYVY ):
// U0Y0V0Y1,U1Y2V1Y3,...
// Sequence of bytes in the destination image is( NV12 ):
// Y plane Y0Y1Y2Y3
// UV plane U0V0U1V1
IPPAPI(IppStatus, ippiYCbCr422ToYCbCr420_8u_C2P2R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDstY, int dstYStep,Ipp8u* pDstCbCr,int dstCbCrStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiCbYCr422ToYCbCr420_8u_C2P2R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDstY, int dstYStep,Ipp8u* pDstCbCr,int dstCbCrStep, IppiSize roiSize ))
// Name: ippiYCbCr422ToYCrCb420_8u_C2P3R, ippiCbYCr422ToYCrCb420_8u_C2P3R
// Purpose: Converts 2-channel YUY2,UYVY images to the 3-plane YV12 image
// Return:
// ippStsNoErr Ok
// Parameters:
// pDst An array of pointers to separate destination color planes.
// dstStep An array of step in bytes through the destination planes
// Notes:
// for ippiYUToYV422_8u_C2P3R sequence of bytes in the source image is( YUY2 ):
// for ippiUYToYV422_8u_C2P3R sequence of bytes in the destination image is( UYVY ):
// Sequence of planes in the destination image is( YV12 ): Y V U
IPPAPI(IppStatus, ippiYCbCr422ToYCrCb420_8u_C2P3R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst[3],int dstStep[3], IppiSize roiSize ))
IPPAPI(IppStatus, ippiCbYCr422ToYCrCb420_8u_C2P3R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst[3],int dstStep[3], IppiSize roiSize ))
// Name: ippiYCbCr422ToYCbCr420_8u_C2P3R
// Purpose: Converts a 2-channel YUY2 image to the I420(IYUV) image
// Name: ippiCbYCr422ToYCbCr420_8u_C2P3R
// Name: ippiYCrCb422ToYCbCr420_8u_C2P3R
// Purpose: Converts a 2-channel YVYU image to the I420(IYUV) image
// Return:
// ippStsNoErr Ok
// ippStsNullPtrErr One or more pointers are NULL
// ippStsSizeErr if roiSize.width < 2 || roiSize.height < 2
// Arguments:
// pSrc pointer to the source image
// srcStep step for the source image
// pDst array of pointers to the components of the destination image
// dstStep array of steps values for every component
// roiSize region of interest to be processed, in pixels
// Notes:
// roiSize.width and roiSize.height should be multiple 2.
IPPAPI(IppStatus, ippiYCbCr422ToYCbCr420_8u_C2P3R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst[3],
IPPAPI(IppStatus, ippiCbYCr422ToYCbCr420_8u_C2P3R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst[3],
IPPAPI(IppStatus, ippiYCrCb422ToYCbCr420_8u_C2P3R,( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst[3],
[/cpp]
Vladimir
Vladimir
// Return:
// ippStsNoErr Ok
// Parameters:
// Notes:
// Y plane Y0Y1Y2Y3
// Return:
// ippStsNoErr Ok
// Parameters:
// Notes:
// Return:
// ippStsNoErr Ok
// Arguments:
// Notes:
[/cpp]
Vladimir
thanks did solve my problems.
No problem reading it understanding it was the problem but i am sorted now thanks.
jurie
