6825 Discussions
Unable to route audio via HDMI to computer monitor with speakers
Nomad_B2
Greetings.
Recently connected a SCEPTRE B30 monitor to a DELL Vostro 15 7510.
I cannot get the audio to pass to the monitors HDMI inputs.
In the Device Manager, HD Audio Driver for Display Audio is present without errors.
In the Sound Control GUI, the only playback devices are Headphones (USB Audio), Line input, Speakers and Headphones (audio plug).  These four devices are all Realtek Audio.
I am hoping that this is a simple setting or check box.
Thank you in advance for your time and help.
Bret B.
Details:
Processor: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
Processor Speed: 2304 MHz
GFX Driver Name: NVIDIA GeForce RTX 3050 Ti Laptop GPU
Shader Version: NA
OpenCL* Version: NA
* Microsoft DirectX* *
Runtime Version: NA
Hardware-Supported Version: NA
Vendor ID: 10DE
Device ID: 25A0
Device Revision: A1
GFX Driver Version: 31.0.15.5161
Dedicated RAM: 4 GB
Shared RAM: 8 GB
Max Supported Displays: NA
GFX Vulcan:
GFX Driver Name: Intel® UHD Graphics
Shader Version: 5.1
OpenCL* Version: 3.0
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 9A60
Device Revision: 01
GFX Driver Version: 31.0.101.4502
Dedicated RAM: 128 MB
Shared RAM: 8 GB
Max Supported Displays: 4
GFX Vulcan: 1.3.250
GFX GOP: 17.0.1061
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Display 1 *
Display Name: Built-In Display
Display Type: Digital
Serial Number: -
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Maximum Image Size
Horizontal - 13.39 inches
Vertical - 7.48 inches
* Digital Display 2 *
Display Name: Sceptre B30
Serial Number: 0000000000001
Gamma: 2.2
Maximum Image Size
Horizontal - 27.17 inches
Vertical - 11.42 inches
Power Management Support
Active Off Mode Supported
Ruqiu_C_Intel
It is a community support channel for Intel® Integrated Performance Primitives software product(Intel IPP). For your support request, please visit product-support-forums or other developer-software-forums , then choose a right channel to post your request. Thank you for understanding.
