Unable to uninstall/install ipp
transcoding
Hello guys,
I wanna uninstall ipp 6.0 and reinstall ipp 5.3 under linux centos 5.3. I'm not able to uninstall ipp 6.0 and I'm getting this error:
ERROR: ERROR: Unable to find rpm tool, please add its location to your PATH and restart uninstallation
Also, I'm not able to install ipp5.3 and I'm getting the same error
ERROR: ERROR: Unable to find rpm tool, please add its location to your PATH and restart installation
Do you have any idea please?
Nikolay_L_Intel
This is known issue, we fixed it in ipp6.1, but unfortunately it is sltill in ipp5.3/6.0
The workarounds:
1) to uninstall ipp6.0
a) please find an installed rpm names and select a proper one based on version:
#> rpm -qa | grep ipp
b) manually remove it with RPM tool:
#> rpm -e --nodeps
2) to install ipp5.3
please start installer with --nonrpm command line key
#> /install/install --nonrpm
BTW, you do not necessary need to remove 6.0 before installing 5.3. Both versions can coexist each other.
Please let me know if you have any problems.
Thank you,
- Nikolay
transcoding
The workarounds:
#> rpm -e --nodeps
Thank you,
- Nikolay
Thank you Nikolay for you help ;-)
I know that I both versions can coexist, but I had some troubles with the version 6.
I uninstalled the v6 and reinstalled the v5.3. I don't think that the problem is due to IPP, I think it's more related to CentOS.
Solved ;-)
