VC1 Decoder - Access Violation Exception
Genady_Malinsky
I use Intel IPP Composer XE 2011 SP1 and ipp-samples_p_7.0.7.064. My machine OS in Win7  32-bit my DirectX version is 11.
When I used the VC1 decoder I got Access Violation Exception as I notice using WinDBG:
This exception may be expected and handled.
eax=00000000 ebx=0bebdb68 ecx=000000f0 edx=000000f0 esi=00094cd1 edi=0b70903c
eip=099d049d esp=09e8eca4 ebp=09b5e3c0 iopl=0 nv up ei pl nz na pe nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00010206
*** WARNING: Unable to verify checksum for d:\UMI\ACS\Bin\Verint.MediaCore.Codecsd.dll
Verint_MediaCore_Codecsd!DecodeBlockACIntra_VC1+0x3d:
099d049d 0fb6142e movzx edx,byte ptr [esi+ebp] ds:0023:09bf3091=??
the exception occurs in DecodeBlockACIntra_VC1 - when I open this function I notice that there is define :
#ifdef VC1_VLD_CHECK
How can I enable this define? I used the build_ia32.bat (cl8) in order to built the audio-video-codecs.
Thanks for your help.
SergeyKostrov
Valued Contributor II
Hi Genady, First of all it is not clear why that warning >>*** WARNING: Unable to verify checksum for d:\UMI\ACS\Bin\Verint.MediaCore.Codecsd.dll is diplayed? Is there any possibility that the Verint.MediaCore.Codecsd.dll is corrupted?
Bernard
Hi Genady
Can you post stack trace of your faulty thread? Can you test this address for beign valid 0x09bf3091?
Bernard
iliyapolak wrote:
Hi Genady
Can you check who is the caller of this function and what are passed parameters "DecodeBlockACIntra_VC1+0x3d:"
