I have a very basic C program that calls ippInit(). When calling ippInit() valgrind on Mac shows conditional jump or move that is dependent on uninitialised values. Is there more function calls I need to do before calling ippInit()? On Linux the same simple program but using the Linux libraries has no issues reported by valgrind.
PROGRAM
1 #include "/dirto/ippcp.h"
2 #include "/dirto/ipp.h"
3 #include <stdio.h>
4
5 static int Init(void* heap)
6 {
7 printf("calling ipp init\n");
8 ippInit(); /* Selects the right optimizations to use */
9
10 (void)heap;
11 return 0;
12 }
13
14
15 int main()
16 {
17 Init(NULL);
18
19 return 0;
20 }
WARNING BY VALGRIND
calling ipp init ==48583== Conditional jump or move depends on uninitialised value(s) ==48583== at 0x10001238F: __intel_ssse3_strrchr (in /usr/local/lib/libippcp-9.0.dylib) ==48583== by 0x100011BB5: DynReload (in /usr/local/lib/libippcp-9.0.dylib) ==48583== by 0x636F6C2F7273752E: ??? ==48583== by 0x6C2F62696C2F6C60: ??? ==48583== by 0x2D70637070696268: ??? ==48583== by 0x696C79642E302E38: ??? ==48583== by 0x100000061: ??? (in ./a.out) ==48583== by 0x1FF000000FEFFFF: ??? ==48583== by 0x1: ??? ==48583== by 0x7FFF5FC38597: ??? (in /usr/lib/dyld) ==48583== by 0x7FFF5FC3FC87: ??? ==48583== by 0x100001007: ??? (in ./a.out)
Hello Jacob,
which IPP version do you use? If you use IPP 9.x - you don't need to call ippInit at all both for static and dynamic linking - it is performed automatically. If you use 8.x or earlier - you also don't need to call ippInit for dynamic linked IPP - it is also initialized automatically at dllmain(), and Init is required for static linking only. In your case - dynamic linking - ippInit() function does nothing and doesn't have any internal conditional jumps - therefore I guess you've faced with Valgrind bug or something else.
regards, Igor
Hi Igor,
Thanks for the response. For the version number it is IPP v9.0. Just as a note I do see a performance increase after calling ippInit and when using the function ippcpGetLibraryVersion in my application I see a difference in library version printed out, between calling and not calling ippInit. Not saying that it shouldn't or dosen't try to find the library automatically without calling ippInit, just that I see a difference. Is this user error on my side?
There is the possibility of a Valgrind issue. After the most recent updates in Mac's OS I wouldn't doubt that it is potentially an issue there, especially if my machine was the only one with the Valgrind warning.
Jacob
Jacob,
Can you suggest what is the out put when calling/not calling ippInit()? For example, what is output of this code:
const IppLibraryVersion* lib = ippcpGetLibVersion();
printf("%s %s %d.%d.%d.%d\n", lib->Name, lib->Version, lib->major, lib->minor, lib->majorBuild, lib- >build);
Chao
