Hi ,
I have downloaded xe composer 2013 sp1 for linux.
I need to have the H.264 samples fo IPP.
Can anyone give me the link to download l_ipp_8.0.0.005_legacy_samples.tgz
Madhav
Madhav,
These sample code are legacy, and not supported. You can get it a from registration center if you have a valid license:
Go to here: https://registrationcenter.intel.com/
After you login, select "Intel® Integrated Performance Primitives for Linux", and select the version 8.0, initial release. You can find that file.
btw, for codec support, have you got chance to check Intel Media SDK product. For h.264 codec, users are suggested to that product, other than the legacy IPP sample code.
Chao
HI
Is version 8.X still available I cannot see it?
the old release can be download from Intel registration center:
After you login in, you can find the old releases.
Chao
Can someone in Intel please provide the where abouts of IPP samples compatbile with Intel C++ Composer XE 2013 SP1 on OSX. As James C has noted version 8.X is actually not available for download.
Please note open source softphone (pjsip) requires the ability to compile speech-codecs in order to make use of G729. As per https://trac.pjsip.org/repos/wiki/Intel_IPP_Codecs#MacOSXInstructions
Hi George,
There are the legacy IPP sample code, and they are not supported in the IPP release now. If you are the old users of the sample code, it can be download from Intel registration center (select the old release, after you login in).:
Chao
Hi Chao,
I don't believe so. Version 8 is not accessible . Earliest release is version 9.1 Please provide clear and confirmed instruction on where to source the IPP sample code (specifically containing speech-codecs project)
George
Hi George,
Please select the IPP products in the "Intel® Parallel Studio XE Composer"
Intel® Parallel Studio XE Composer Edition for C++ OS X*
--> Intel® Integrated Performance Primitives for OS X*
You will see different versions of IPPs, The sample is included in the related file. please check if you can find them.
thanks,
Chao
Hi Chao
Is this still available, I tried but I dont see this available any more. Please help me, how to download it?
Chetan...
This version of IPP no longer supported and no available for download. There are only 3 latest IPP versions available for download from Intel Registration Center: IPP vv.2020, 2019 and 2018.
Thanks Gannady
Can I request for it? is there way I can request and get it from Intel Support Team.
Chetan
