Where is FFTSpec_R_64f defined?
cernek
As I mentioned in a previous posting, I am migrating some C++ code, which uses IPP functions, to MS/VB .Net 2005. The only remaining compiler complaints have to do with a reference to the 'type'IppsFFTSpec_R_64f -- it can't find a declaration. Looking at the original C++ code I find, in ipps.h, the following:
typedef
struct FFTSpec_R_64f IppsFFTSpec_R_64f;
The C compiler has no problems with this. However, I cannot find a definition for FFTSpec_R_64f. What am I missing?
Any guidance greatly appreciated.
Ed
Albert_Stepanov
Hi, Ed!
You don't need to care of type of the hidden structures. Use type IntPtr for using it. Here the simple example:
Imports
System
Imports
System.IO
Imports
System.Runtime.InteropServices
Imports
ipp
Module Module1
Sub Main()
Dim st As ipp.IppStatus
Dim pFFTSpec() As IntPtr = {0}
Dim ppFFTSpec As IntPtr = Marshal.UnsafeAddrOfPinnedArrayElement(pFFTSpec, 0)
Dim X(7), Y(9) As Double
For n As Integer = 0 To 7
X(n) = Math.Cos(2 * Math.PI * n * 16 / 64)
Next
Dim pX As IntPtr = Marshal.UnsafeAddrOfPinnedArrayElement(X, 0)
Dim pY As IntPtr = Marshal.UnsafeAddrOfPinnedArrayElement(Y, 0)
st = ipp.sp.ippsFFTInitAlloc_R_64f(ppFFTSpec, 3, 8, 0)
st = ipp.sp.ippsFFTFwd_RToCCS_64f(pX, pY, pFFTSpec(0), 0)
st = ipp.sp.ippsFFTFree_R_64f(pFFTSpec(0))
st = ipp.sp.ippsMagnitude_64fc(pY, pX, 4)
For i As Integer = 0 To 3
Console.Write(
"{0:F} ", X(i))
Next
Console.WriteLine()
End Sub
End
Module
Albert
cernek
The compiler is happy now. Thanks to all for the help. There are still other issues to be worked, but they don't involve the IPP.
