I need the following clarification from Intel IPP support team:
I want to use IPP library for compression of YUV422 video stream into H.264 video stream.
Currently, I am converting first YUV422 to YUV420 using IPP API, and then convert from YUV420 to H264. This is working fine for me.
However I want to avoid YUV422 to YUV420 conversion.
Whether IPP library can convert YUV422 format directly into H.264 format? If yes, can you please provide a sample codr for the same.
Abhishek Jain
Hello Abhishek,
Have you got the chance to check Intel Media SDK:
http://software.intel.com/en-us/vcsource/tools/media-sdk
In the IPP8.0, the UMC sample code moved to the leagay code. The media can take the advantage of the GPU performance.
Chao
