6832 Discussions
apply LUT sequence from Dicom image from 0028,3006 tag
Purushoth
I try to create a pallete using 0028,3006 Dicom tag and apply it over DICOM image using ippiLUTPalette function but the image I get is darker.
My input image is 12 bit and LUT data is 12 bit. can someone suggest some sample codes it would be helpful
Ruqiu_C_Intel
Hi Purushoth,
Thank you for contacting to us.
There is an example for ippiLUTPalette in Intel IPP Developer Guide and Reference. If you didn't review it before, please check the linkage here: LUTPalette, LUTPaletteSwap (intel.com)
The number of significant bits nBitSize should be in the range [1, 8] for functions that operate on 8u source images, and [1, 16] for functions that operate on 16u source images.
Ruqiu
Ruqiu_C_Intel
Hi Purushoth,
Ruqiu
Purushoth
I have tried this and got desired output thanks for your response
