Community
cancel
Showing results for
Search instead for
Did you mean:
error C2065: 'ippiCopyCopySubpix_8u_C1R' : undeclared identifier
Jump to solution
Dear experts:
i want touse the ippiCopyCopySubpix_8u_C1R or ippiCopySubpixIntersect_8u_C1R function
then i got the message from the VC6.0 Compiler
: error C2065: 'ippiCopyCopySubpix_8u_C1R' : undeclared identifier
and i have include "ippi.h",but in ippi.h i couldn't find this function
Thanks for your reply.
Accepted Solutions
Quoting - Wenlei Song
Gennady,
thanks!but "undeclared identifier" means i can't find the function declaration.and ihave triedto link my application whith ippcv.lib,the complier also told me "error C2065: 'ippiCopyCopySubpix_8u_C1R' : undeclared identifier"
How about include "ippcv.h" ortouse #include "ipp.h", which shouldinclude all ipp functions?
Ying
Dear experts:
Wenlei,
you have to link your application with ippcv.lib in case of dynamic linking mode and/or ippcvemerged.lib ippcvmerged.lib in case of static.
Please refer to the article to find out more about IPP linkage mode
--Gennady
Wenlei,
--Gennady
Gennady,
Gennady,
Ying
Quoting - Ying H (Intel)
Ying
Ying,
thanks.i find the functions in "ippcv.h".so in document "ippiman.pdf",there are two errors:
IppStatus ippiCopyCopySubpix_(const Ipp* pSrc, int srcStep,
Ipp* pDst, int dstStep, IppiSize roiSize, Ipp32f dx, Ipp32f dy);
the real function is ippiCopySubpix_,not double Copy
and
The function ippiCopySubpix is declared in the ippi.h file.
The function ippiCopySubpixIntersect is declared in the ippi.h
then "ippcv.h" should instead of "ippi.h"
wenleiSong
Thanks, we will check and correct ippiman.pdf if there is a typo.
Sorry, Ican'tagree with where ippiCopySubpix/CopySubpixIntersect are decrlared. They definetely declared in ippcv.h not in ippi.h. Please double check.
Vladimir
