error: LNK2019 unresolved external symbol
codiebank
I have to use the speech codecs(g711) in my c# code.I have downloaded the code from speech codecs froim intel IPP samples.As i have to use the code in c# codes i tried adding the code in VC++ so that i can make the dll and use it directly
,as per the steps given on this forum only.
I am not able to build the project and it is giving the following errors:
1.
Error 2 error LNK2019: unresolved external symbol _apiG729Decoder_Alloc referenced in function _DecoderObjSize decg711.obj G711cpp
2.Error 12 error LNK2001: unresolved external symbol _ExpPosNormTbl plcg711.obj G711cpp
3.
Error 15 fatal error LNK1120: 13 unresolved externals Debug\G711cpp.exe G711cpp
Any help will be highly appreciated.
Ying_H_Intel
Quoting - codiebank
1.
3.
Error 15 fatal error LNK1120: 13 unresolved externals DebugG711cpp.exe G711cpp
Hello
In general the message of unresolved external symbol show because the file or library where symbol is implemented is missing.
For example, api729Decoder_Alloc is implemented in decg729.c, which is not in directory g711 , but in directory g729i, so you need include the decg729.c, decg729.h (may more) file in your preject.
if the unresolved external symbol is "_ipp*", then ipp library is missing.
for more details, please refer to
http://software.intel.com/en-us/articles/intel-integrated-performance-primitives-intel-ipp-for-windows-lnk2001-unresolved-external-symbol-_ipp
Hope it helps
Ying H.
