I have some trouble by calling the ippiResize function.
I get a exception and can catch it only with catch(...) so I can't check what kind of exception it is.
I read something of exceptions with IPP but it should be platform dependend. I'am working with windows and MSVC .Net 2003 compiler.
The problem is the same with IPP 5.1 and 4.1.3
I also checked the src and dst data but it seems to be corrct pointer with allocated memory.
Maybe there is some information what the problem could be, I think about memory access problem, but I don't know that there is a exception for.
Best regards
Peter
Best regards
Peter
Hi Peter,
could you please post simple test case here?
Vladimir
I solved the problem. Because of a special API I swaped the height and width and so there was a memory problem.
Anyway I wonder that there is a exception that will be thrown by that memory acces problem, because I thought that there should be program termination.
Nevertheless thx for reply.
Ok, great. Thanks for informing us.
Vladimir
