exponential of complex data after DFT
j3r3mi
After DFT, i have a complex output of typed Ipp32fc, but there isn't any API in ippi.h that does exponential on complex numbers. I used API from ipps.h to achieve this row by row vector in a for-loop. This operation took 1/3 of my execution time. I wonder if others are actually facing the same problem as me. Any workaround or better solution??
Thanks in advance!
Thomas_Jensen1
If your input image is Real (no imaginary part), then it could be that your output is also real, and then you only have to do the Exp on a Ipp32f (after having converted the output of the DFT from complex to single.
I had to do that once with homomorphic filtering. Is that what you are doing also?
j3r3mi
Actually 'm working on spectral residue. F'[exp(Mag(F) + jPhase(F)]. F' is the inverse fourier transform. Anyway thanks for reply.
