ipp 5.1 Error loading libippsr.so.5.1 on RH5
rosali99
We've been using ipp 5.1 on linux redhat4 sucessfully, but after upgrading the server to redhat 5 an attamt to run our sofrware gives the following error:
error while loading shared libraries: libippsr.so.5.1: cannot restore segment prot after reloc: Permission denied
What cases the problem? How do we resolve that issue?
Please help!
mecej4
The upgrade probably caused SeLinux to be activated. Your server administrator should be able to suggest a solution consistent with local security policy.
Naveen_G_Intel
Quoting rosali99
Please help!
This problem is most probably caused by the security extension SeLinux, please check with system administrator.
Naveen Gv
