ipp 7.0 crash on Intel(R) Core(TM) i3-2100 CPU
songzhe
ipp version: 7.0.4
code:
#include
#include
int main()
IppCpuType cpuType = ippGetCpuType();
if(ippInitCpu(cpuType) != ippStsNoErr)
printf("ippInitCpu(%d) failed", cpuType);
else
printf("ippInitCpu(%d) successed", cpuType);
char buffer[1024];
ippsZero_8u(buffer, sizeof(buffer));
return 0;
os: CentOS release 5.5 (Final)
CPU type: Intel Core i3-2100 CPU @ 3.10GHz
compile command line: gcc -o t main.c -I$IPPROOT/include -L$IPPROOT/lib/intel64 -lipps_l -lippcore_l
gcc version: 4.1.2 20080704 (Red Hat 4.1.2-48)
run result: Illegal instruction (core dumped)
gdb where:
(gdb) where
#0 0x0000000000400d96 in e9_ownsZero_8u_E9 ()
#1 0x0000000000400627 in e9_ippsZero_8u ()
#2 0x00000000004005e8 in main ()
Does ipp 7.0.4 sitll has bug on this CPU(Intel Core i3-2100 CPU @ 3.10GHz)?
songzhe
core dump occurs on both 7.0.3 and 7.0.4
songzhe
it's ok in dynamic link mode, but static link mode will core dump
Chao_Y_Intel
Hi songzhe,
Thanks for your report. We are checking this problem now. Does it only happen with ippsZero_8u function, or you find the problem when you call other IPP function?
Chao
songzhe
Hi Chao:
I think it happans on all functions;My application crashed on this CPU in static link mode, so I just choose a simple funtion ( ippsZero_8u ) to ensure weather it's my bug.
Chao_Y_Intel
The AVX instruction needs explicit operating system support: http://en.wikipedia.org/wiki/Advanced_Vector_Extensions
Could you please check this version Linux distribution support the AVX instructions?
Also, Could you please remove the following code, this will force IPP run AVX instruction.
else
Instead, you can use ippInit() function to let IPP select the dispatching code.
Chao
