ippi: Grayscale 16-bit
John_M_1
I noticed that there aren't many functions available on Image Processing that support Grayscale 16-bit.
For example, If I want to scale an image on Grayscale 16 format where bytes per pixel == 2, the function ippiResizeLinear_8u_C1R doesn't work properly, nor ippiResizeLinear_8u_C3R.
So to use Intel IPP for this purpose on this type of images, should I then convert the images to RGB? And from what I could see there is no function in IPP for doing that for me.
What would be suggested?
Aris_Basic
there are many :)
you have to use ippiResizeLinear_16u_C1R for example
and similar colors 16u or 16s depending on your 16bit image data
Aris_Basic
there are many :)
