6825 Discussions
ippiDCT with other blocksize (i.e. 4x4 instead of 8x8)
hajo_hoffmann
I try to use the ippiDCT for images with a different blocksize. But it seems to have a hardcoded 8x8 blocksize. Did I miss something?
If it is not possible I have to create my own implementation of the DCT :-/
One other issue:
My first experiments with the ippiDCT is not working as expected.
I just tried to calculate the DCT of an IplImage (OpenCV image format) and the inverseDCT of the result ... but I did not get the original image after the second step ... why?
-- Code ----------------------------
// Fwd DCT:
ippStat = ippiDCTFwdInitAlloc_32f (&dctFSpec, ippiROI, ippAlgHintNone);
ippStat = ippiDCTFwd_32f_C3R((Ipp32f*)image->imageData, image->widthStep, (Ipp32f*)dctImg->imageData, dctImg->widthStep, dctFSpec, NULL);
// Inv DCT:
ippStat = ippiDCTInvInitAlloc_32f (&dctISpec, ippiROI, ippAlgHintNone);
ippStat = ippiDCTInv_32f_C3R((Ipp32f*)dctImg->imageData, dctImg->widthStep, (Ipp32f*)tmpImg->imageData, tmpImg->widthStep, dctISpec, NULL);
best regards
Hajo Hoffmann
Vladimir_Dudnik
IPP DCT functions developed to work with any reasonable ROI sizes (not only 8x8). There can be some difference after Fwd-Inv DCT operations in comparison with original image, mainly because of rounding errors. If you have completely different result you need to check code and data you are using.
Vladimir
