6831 Discussions
ippiDeinterlaceMotionAdaptive_8u_C1() source planes order
li__steve
The function ippiDeinterlaceMotionAdaptive_8u_C1() takes an array of 4 source planes. I would like to know if I should put the earliest plane in index 0 or index 3 of the array.
For example, I have planes t0, t1, t2, and t3. Video starts with plane t0, followed by t1, then t2, and t3. Should I setup my array such that:
srcPlanes[0] = t0;
srcPlanes[1] = t1;
srcPlanes[2] = t2;
srcPlanes[3] = t3;
OR
srcPlanes[0] = t3;
srcPlanes[1] = t2;
srcPlanes[2] = t1;
srcPlanes[3] = t0;
Steve
Chao_Y_Intel
Steve,
The followingscenario may help you understand theusge of this function (ippiDeinterlaceMotionAdaptive_8u_C1()):
Suppose I have 4 fields for 2 frames, frame size(720x480), field size(720x240), frame time is 0.03 sec.
FrameA=interlace(Field1+Field2)
FrameB=interlace(Field3+Field4)
FrameC=interlace(Field5+Field6)
FrameD=interlace(Field7+Field8)
The playtime is: FrameA(0.03)-FrameB(0.06)-FrameC(0.09)-FrameD(0.12)
To learn:
1. How to set "pSrcPlane[4]"? frame or field? array[0] is previous or next?
2. What to get in "pDst"? what is its output dimension?
3. What does "copyField" mean?
pSrcPlane[0] = FrameA (interlaced, weaved of Field1 and Field2)
pSrcPlane[1] = FrameB
pSrcPlane[2] = FrameC
pSrcPlane[3] = FrameD
dstStep = srcStep = 720 (+ padding)
Assume Field1 is the top one,
field times: Field1 - 0.03 sec, Field2 - 0.045 sec, Field3 - 0.06 sec, etc.
If one wants 30 deinterlaced frames per second, with the frame playing times equal to those of the odd (first) fields:
ippiDeinterlaceMotionAdaptive_8u_C1(pSrcPlane, ..., topFirst=1, topField=0, copyField=1, ...)
will write to pDst a 720x480 frame, with the top field copied from frame C, and the bottom field generated (interpolated),
Which means one will get a deinterlaced frame at 0.09 sec.
If copyField==0, the top field in pDst will be left unchanged (imagine one has already copied frame C to pDst).
To obtain a DI frame at 0.12 sec, one needs to update pSrcPlane:
pSrcPlane[0] = FrameB
pSrcPlane[1] = FrameC
pSrcPlane[2] = FrameD
pSrcPlane[3] = FrameE
If one has bottom field first (Field1 is the bottom one), and frames' playtimes are still 0.09, 0.12, etc:
ippiDeinterlaceMotionAdaptive_8u_C1(pSrcPlane, ..., topFirst=0, topField=1, copyField=1, ...)
To generate output frames 0.075, 0.105, etc sec, topField should be set to topFirst.
With A,B,C,D interlaced frames at input,
pDst will contain a frame consisting of the unchanged temporaly second field of frame B, and the first field interpolated.
Calling the function twice for each quartet of input frames:
ippiDeinterlaceMotionAdaptive_8u_C1(pSrcPlane, ..., topFirst=1, topField=1, ...)
ippiDeinterlaceMotionAdaptive_8u_C1(pSrcPlane, ..., topFirst=1, topField=0, ...)
one will end up with a deinterlaced frame for every input field: 60 deinterlaced frames per second in our case, frame playtimes 0.075, 0.09, 0.105, etc.
Chao
