ippiDilateBorder_8u_C1R performing worse on faster Intel proccessor - IPP 2017 Upd 3
Nikhil_D_1
We are running into a strange issue with ippiDilate/Erode. It runs fine on multiple dev machines with varying vintage but exhibits huge timing numbers on our production PCs
  1. Dev1- Intel i72700K - 2-3 ms OK,
  2. Dev2 - Intel i7-8700 OK,
  3. Production - Intel i9-7940X - Massive overtiming 30-40 ms for same function
We use other filters without issues on the same PC and timing numbers usually correlate with age of Intel chip speed.
OS - Windows 7, Win 10, IPP 2017 Update 3, static linking
Any ideas what might be causing this
Nikhil_D_1
Image Size: 1920x540, Kernel Sz= 3x3
Gennady_F_Intel
Nikhil, could you give us the reproducer which we will use for reproducing the problem on our side with different versions of IPP, OS and CPU?
Nikhil_D_1
Apologies for the delay. I will see about getting you a test project
