ippiMirror flip problem
panda2420
Hi
we are trying to flip a matrix with the ippiMirror function of the new ipp 6 released version.
We are testing all possible cases, so we also try to flip a matrix that is actually a vector (the size of one of the dimentions is one) - we are aware that the result is the same vector , but we check it just the same.
In your documentation it is written that if the Roe size is either 0 or negative an error is thrown, but we recieve the same error in the case of the vector flipping( ippStsSizeError).
Is this a normal behavior ? becuase in version 3 (which was the last version we used) it was not the case - and these tests passed.
Thank you
Dana.
