ippiResizeFilterInit parameter options
pvonkaenel
New Contributor III
I've been using the resizers in the ResizeSqrPixel() call, and tend to allocate intermediate space for the largest image I'll be resizing. Is this also possible for the Hann resizer available in ippiResizeFilter? Basically, can I allocate space for the largest image I'll work with and then call ippiResizeFilterInit() only once, or do I need to call ippiResizeFilterInit() for every different image size?
Peter
Chao_Y_Intel
Hi Peter,
It looks the same problem in the premier support issue. I provided an update.
For other users here, it needs to call ippiResizeFilterInit() for every different image size because the function builds filter depending input/output size.
Chao
pvonkaenel
New Contributor III
Thanks Chao, I'll be sure to call the init when changing image sizes.
Peter
