6847 Discussions
ippiRotate and non-square image (width != height)
john_gehringstabiles
Can I use ippiRotate to rotate a 640x480 image without loosing any part of the image? Right now I keep loosing the right side of the image (160 columns of the original orientation). The documentation is leading me to believe that you only get the intersection of the source and destination ROI's, but isn't there a way to rotate a rectangle without loosing part of the image?
petemoss
You can rotate cleanly if you rotate into a larger canvas. Make a larger image buffer, with a larger ROI, and use that as the Dest. If you rotate into an image of the same size, then you will lose part of the image, because there is no where to put it.
