6831 Discussions
ippsGFpECPrivateKey for std521r1 elliptic curve issue: Error -6.
jlabbe
Hi Team,
I'm struggling to use the method ippsGFpECPrivateKey for an elliptic curve configured following this process:
1) Create Gallois Field using:
ippsGFpInitFixed(521, ippsGFpMethod_p521r1(), gf_output);
gf_output size is 1768.
2) Create Elliptic Curve using:
ippsGFpECInitStd521r1(gf_output_GF, ec_output)
Note that ec_output was first reseat with ec_size_output (4064) extracted from
ippsGFpECGetSize(gf_output_GF, ec_size_output)
3) Create BigNum using:
ippsECCPGetSizeStd521r1(secret_key_size_output)
convert secret_key_size_output (12808) into secret_key_size_word (401)
ippsBigNumGetSize(secret_key_size_word, bn_size_output)
big_num now reseat with bn_size_output (3271)
ippsBigNumInit(secret_key_size_word, big_num)
4) Now onto using ippsGFpECPrivateKey
ippsGFpECPrivateKey(secret_key(size=3271), elliptic_curve(size=4064), randfunc, randctx)
The error returned is -6.
I can see from the documentation that -6 "Indicates an error condition if the parameter pointed to by pPrivate has a memory size that is less than the order n of the elliptic curve base point G."
This same process does produce the correct results, for std256r1 and std384r1, would somebody understand what i'm doing wrong for std521r1?
Ruqiu_C_Intel
Can you tell us your OS, IPP version, and CPU information, as well as a simple reproducer for this problem?
jlabbe
Hi Ruqiu,
Thanks for the response.
I believe my problem is now gone.
Trying to create a simple reproducer, I realised that the randfunc() was the one sending back the ippStsSizeErr error...
Jeremie
Ruqiu_C_Intel
Hi Jeremie,
Thank you let us know the issue is gone.
And glad to know that you found out the real issue in your code when trying to create a reproducer.
Best,
Ruqiu
