6832 Discussions
ippsRijndael128EncryptCBC fails for input files larger than 33MB
o_ganot
Iv'e implemented a C++ native dll which allocates a CTR(counter) mode/CBC mode session, encrypts and decrypts buffers.
Iv'e implemented a corresponding C# tester, which takes an input file, and using BinaryReader, readsthe file buffer-buffer, encryptseach buffer using the dll above and writes the encrypted file using a BinaryWriter.
Iv'e tested encryption in CTR mode using different file sizes and different buffer sizes, and all succeeded.
When I tested encryption in CBC mode, I found out that input files larger than 33MB fail in the middle of encryption, producing the error:
ippStsUnderRunErr = -124, /* Data under run error */
I tried changing the buffer size, but the error presists. I tried using CTR mode on the same file (34MB) and it succeeded.
Here is the tester code:
Encrypt a file
/// the handle of the session to use
/// the file to encrypt
/// the encrypted file
/// const IV to be used
private bool EncryptFile(uint SessionHandle, string InFile,
string OutFile, byte[] IV, int BlockSize, out TimeSpan TestDuration)
// Init output params
TestDuration =
TimeSpan.MinValue;
// Open the input file
FileStream Infs = new FileStream(InFile, FileMode.Open, FileAccess.Read);
if(Infs.Length == 0)
MessageBox.Show("Input file is empty", "AES Transform Tester",
MessageBoxButtons.OK, MessageBoxIcon.Error);
Infs.Close();
return false;
// Create the output file
FileStream Outfs = new FileStream(OutFile, FileMode.Create, FileAccess.Write);
BinaryReader br = new BinaryReader(Infs);
BinaryWriter bw = new BinaryWriter(Outfs,System.Text.Encoding.Default);
byte[] PlainTextBlock;
byte[] EncryptedBlock;
try
// Get the current time
DateTime TestStart = DateTime.Now;
// Read the file block by block
while((PlainTextBlock = br.ReadBytes(BlockSize)).Length != 0)
// Encrypt the byte array
EncryptedBlock =
new byte[PlainTextBlock.Length];
if(!AESTstrUtil.EncryptPacket(SessionHandle,PlainTextBlock,
IV, EncryptedBlock))
MessageBox.Show("Failed to encrypt block", "AE S Transform Tester",
return false;
bw.Write(EncryptedBlock);
// Set the test duration
TestDuration =
DateTime.Now - TestStart;
finally
bw.Close();
Outfs.Close();
br.Close();
Infs.Close();
return true;
Any ideas / same experience?
Chao_Y_Intel
HI,
Some suggest from expert for this problem:
The single case when ippsRijndael128EncryptCBC() returns ippStsUnderRunErr status is
0!=(len%16) and padding==NONE, where len is data length (in bytes ) to be encrypted.
Pay attention that behavior of all symmetric ciphers has been changed in IPP v5.1 - padding scheme parameter does not use actually and always assumes NONE
o_ganot
I just found out myself that indeed the case you suggested was the one I confronted.
I think that a different error name or appropriate documentation (Iv'e looked for such anywhere) would have prevented the mess I got in...
