lippvc error message
cla-12345
Greetings,
I'm trying to compile the IPP sample MPEG 2 encoder for Linux, and amreceiving the following error:
/usr/bin/ld: cannot find -lippvc
collect2: ld returned 1 exit status
I can barely spell "Linux", so any suggestions would be very much appreciated by this newbie.
Thanks!
Message Edited by [email protected] on 12-11-2004 05:43 PM
Message Edited by [email protected] on 12-11-2004 05:44 PM
Vladimir_Dudnik
Hi
it seems you use shared IPP libraries. If you trying to compile with evaluation version, please be noticed that evaluation version does not contain shared libraries.
Vladimir
cla-12345
Hi Vladimir,
Thanks for the reply. I am using the non-commercial version of the IPP, rather than the evaluation version. Based on the following information from theNon-Commercial FAQon Intel's web site (see link below), it was my understanding that itis a complete package. Is that not correct? Thanks again!
Vladimir_Dudnik
non-commercial version should include shared libraries. Actually, you can easely check this, right? So, probably the problem is in Makefile you are using. It seems for me that the path to library was set in wrong place. Can you verify that?
Vladimir
