6847 Discussions
project file or solution file for sample code for IPP JPEG encoder/decoder
fanguts
I downloaded some IPP sample code. I could not find project file or solution file in sample code ? would you provide these? I would trace the sample code and do some integration to my program. Thank you very muck
Fanguts
pvonkaenel
New Contributor III
Quoting - fanguts
Fanguts
Which sample are you referring to and for which version of IPP? Looking at the IJG samples for IPP 6.1 there is a solution and project files. If you are trying to use the UIC sample, then thereare build32 and buildem64t batch files which build from the command line.
fanguts
Quoting - fanguts
Fanguts
Thanks for response. I am trying JPEGview (basicly I want to convert Bmp to JPEG). but I couldn't find project/solution file.
yes, you provided a solution file for example ippidemo, but that is just for bmp file process.
fanguts
Quoting - pvonkaenel
yes, you provided a solution file for example ippidemo, but that is just for bmp file process. thank you again
Ying_H_Intel
Hello fanguts,
I have one MSVC 2005 project of JPEGview (butfor previousIPP version, 5.3.x). I upload it here for your reference.
thedirectory structure is a little deep. Please find the *.sln file at jpegviewjpegviewjpegviewjpepViewjpepView.sln ( and keep thedirectory structure).
Ying
fanguts
Quoting - Ying Hu (Intel)
Hello fanguts,
Ying
Ying, thank you for your help. now everyting is fine
