"a.out" received signal SIGILL, Illegal instruction. 0x000000000051a8d8 in l9_ippiFilterSobelNegVertBorder_8u16s_C1R () (gdb)
nadaf__salman
Hello everyone,
I am using canny edge detection function from intel IPP. Actually I am just using the sample code from documentation. I am reading a 8bit gray scale(.bmp) image and applying canny function to get edges of that particular image and again I am storing that into output image (.bmp).
1]When I am not using any opencv funtion program executes without any error but the output image is just blank(Black) image with same size as that of source image.
2]After adding opencv libraries and using cv::imshow function I am getting SIGILL signal. I have attached code below. I know this is not a standard way of writing code but still just checking the functionality please ignore it.
When I am executing the code with gdb it is showing
(gdb)
Kindly help me to overcome this problem. In both the cases where I am going wrong please let me know. Thank you.
Salman
nadaf__salman
Hi, evryone.
I got the solution for 1st problem.
1] I was skipping the Color table part. ie. I hadn't written color table in output image so it was blank(black). So I did have solved this problem. But not sure about 2nd one why it is giving SIGILL signal.
If someone figure it out ,please let me know. I appreciate any kind of help. Thank you.
