6707 Discussions
unexpected results with intel primitive (when dividing by 1)
Josephnyu
I'm using Intel Integrated Performance Primitives (windows, v2019 (2019.0.5.1052), 64bit) and I came across unexpected results.
When I run the following code
    std::cout << std::setprecision(20);
    const int N = 8;
    const std::vector<double> one(N, 1.0);
    std::vector<double> d(N,0.014058305571221497);
    std::cout << "before division by 1 : " << d[0] << std::endl;
    ippsDiv_64f_I(one.data(), d.data(), N);
    std::cout << "after division by 1 : " << d[0] << std::endl;
I get the following output :
before division by 1 : 0.014058305571221497293
after division by 1 : 0.014058305571221500763
1/ How dividing by 1 can change the value ?
2/ For any value of N between 1 and 7, dividing by 1 has no effect. Only for N>7 I get this. How can it be that the result of a division of doubles depend on the size of my array ?
Could it be a bug ?
Note : I tested with v2022 and I got the same results
Ruqiu_C_Intel
Hello Josephnyu,
Thank you for posting your concern here.
We have reproduced it, and will investigate further internally for the accuracy.
Ruqiu
Chao_Y_Intel
Hi Josephnyu,
In the double-precision floating-point format, the fractional part is 52 bits: https://en.wikipedia.org/wiki/Double-precision_floating-point_format
The precision of this format is around 15 decimal digits: 2^52 ~ 10^15.
IPP functions are optimized using various instructions, which may result in minor rounding differences at the least significant bits. In the test code provided, the difference is around the 10^-15 level. This looks an acceptable numerical discrepancy.
For larger values of N, such as N >= 8, vectorized instructions (AVX512/AVX2) can be utilized. For smaller values of N, scalar instructions are used. so the final result may have differences within its precision range.
Chao
Josephnyu
Thanks @Chao_Y_Intel
The difference between the result that I get and the expected results is 2ULP. So the "rounding" impacts more than 1 bit.
Deciding if the discrepancy is acceptable or not depends highly on the usage. If I divide 1milion times by 1 can I get very far from my starting point ?
Does intel provide any guarantee about the error of the results ? If yes can you please share tem.
I'd like also confirmation that there is no bug and that's those results are compliant with the specs of IPP.
Gennady_F_Intel
you could try to check the behavior with  ippsDiv_64f_A53 function which guarantees 53 correctly rounded bits of significand, including the implied bit, with the maximum guaranteed error within 1 ulp.
The API of this function is slightly different compare with ippsDiv_64f_I.
Josephnyu
Thanks for the suggestion @Gennady_F_Intel.
I tested  ippsDiv_64f_A50 and  ippsDiv_64f_A53 on this test case and they returned the expected results.
Perf of ippsDiv_64f_A50 is similar ippsDiv_64f_I.
However perf of ippsDiv_64f_A53 is worst by ~8%.
Can you tell how many ulps are gauranteed by ippsDiv_64f_I ?
Chao_Y_Intel
thanks,  Josephyu.  We are checking it with the function owner, to make sure the result is expected.
