why would i need planes for
mh_de_ruiter
why should (and what is it?) 'planes' for ?
are planes layer ? of different images ?
or is plane 1 .. the reds
plane 2 the green
and plane 3 the blue ?
i do not understand
if i want to work with a 32 bits image with alpha channel
what do i need to use with imalloc ?
with using CreateDIBSection, i'll never have any plane
(i'm not english but dutch, and i looked everywhere, but i just don't get the idea of plane)
please someone explain,
friendly greetings,
Menno de Ruiter
Vladimir_Dudnik
you know, multi-channels images can be represented by different ways. In pixel-interleaved representation each pixel's color values are adjacent in memory. For 4 channel 4x3 image it look like this
c0c1c2c3 c0c1c2c3 c0c1c2c3 c0c1c2c3
whereas for plan-interleaved images each color values are grouped into different arrays. For example, for 4 channel 4x3 image:
c0c0c0c0
c0c0c0c0
c0c0c0c0
c1c1c1c1
c1c1c1c1
c1c1c1c1
c2c2c2c2
c2c2c2c2
c2c2c2c2
c3c3c3c3
c3c3c3c3
c3c3c3c3
Hope, this help.
Vladimir
mh_de_ruiter
ah, ok,
so, like typical cyan magenta etc. stuff.. i use 4planes for output/sereration etc. ok..
Is there anypreferred used method for a 'normal' RGB & Alpha images (like an BMP with alpha channel or tga).. is this the 8u_AC4 ? or does this have a maximum or 256 colors (for each pixel) ? or does this have because there are 3 rgb channels of each 8 bits thus a full 24 bits 16 million color image ?
this is where i get confused... does 8u_ means it holds 8 bits on each color/C(hannel).. or do i need 32s_AC4 ? or is this a extreme way of producing extreme billinos of collors ?
is 8u_C3 being used for a 'normal' rgb 25 bits color bitmap ?
or a 32s_C1 (or 32s_C3) ?
Friendly Regards,
Menno de Ruiter
