Intel® MPI Library
2279 Discussions
Conda impi_rt=2019.1 doesn't substitute I_MPI_ROOT in bin/mpivars.sh
Liu__Ke
Not sure where to report this bug, but this forces me stick with intelpython 2018.0.3. The steps to reproduce are
conda config --add channels intel
conda create -n test impi_rt=2019.1
You will find /path/to/envs/test/bin/mpivars.sh has I_MPI_ROOT not substituted correctly.
Or is conda no longer the supported way to install Intel Performance Libraries? If so, what's the most future proof way? Or if it is the best way, where should I report this bug? Thanks.
James_T_Intel
Our engineering team is already aware of this.  The fix will be available in Intel® MPI Library 2019 Update 3.
Liu__Ke
Seems like it is neither fixed in 2019.3 nor 2019.4. How do other people typically workaround this problem?
