Intel® MPI Library
Fata Error using MPI in Linux
guccione__pietro
I'm using a virtual Linux Ubuntu machine (Linux-VirtualBox 4.4.0-101-generic #124-Ubuntu SMP Fri Nov 10 18:29:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux), with 8GB RAM.
For a process on Matlab, the software requires Intel MPI runtime package v4.1.3.045 or superior. Instead, I've installed the 2018.1.163 version, being not sure about the 2018 number version.
Using 8 cores in the processing, the software went in error, with the following error:
Fatal error in MPI_Recv: Other MPI error, error stack:
MPI_Recv(224)...................: MPI_Recv(buf=0x7f566d59c040, count=9942500, MPI_FLOAT, src=3, tag=5, MPI_COMM_WORLD, status=0x7ffc43a72b60) failed
PMPIDI_CH3I_Progress(658).......: fail failed
MPID_nem_handle_pkt(1450).......: fail failed
pkt_RTS_handler(317)............: fail failed
do_cts(662).....................: fail failed
MPID_nem_lmt_dcp_start_recv(302): fail failed
dcp_recv(165)...................: Internal MPI error!  Cannot read from remote process
 Two workarounds have been identified for this issue:
 1) Enable ptrace for non-root users with:
    echo 0 | sudo tee /proc/sys/kernel/yama/ptrace_scope
 2) Or, use:
    I_MPI_SHM_LMT=shm
Reducing the number of cores to 4, the process hangs for more than 3 hours and I'm not sure it is still working.
What could be the problem?
thank you
Pietro
Arige__Krishna
As suggested in the error:
you can run the command
I_MPI_SHM_LMT=shm
You can read more details about it at
https://software.intel.com/en-us/mpi-developer-reference-linux-shared-memory-control
It means: large message transfer (LMT)  mechanism for the shared memory
Also, you can edit ptrace value from 1 to 0 by
but, this might not be recommended,
read more about the Ptrace value
https://www.kernel.org/doc/Documentation/security/Yama.txt ;
