Intel® MPI Library
2285 Discussions
HPCC benchmark failing with Intel MPI
bwillems
I 've compiled the HPCC benchmark suite (http://icl.cs.utk.edu/hpcc/) with Intel MPI, but am facing the following run-time problem:
[bart@head 2x8]$ /share/intel/impi/3.2.1.009/bin64/mpirun -f 1.nodelist -n 16 -r ssh ./hpcc
node002:27686: reg_mr Cannot allocate memory
node001:2835: reg_mr Cannot allocate memory
node002:27684: reg_mr Cannot allocate memory
node002:27679: reg_mr Cannot allocate memory
node001:2834: reg_mr Cannot allocate memory
node001:2839: reg_mr Cannot allocate memory
node002:27681: reg_mr Cannot allocate memory
node002:27682: reg_mr Cannot allocate memory
node002:27685: reg_mr Cannot allocate memory
node002:27680: reg_mr Cannot allocate memory
node001:2833: reg_mr Cannot allocate memory
node001:2838: reg_mr Cannot allocate memory
node001:2836: reg_mr Cannot allocate memory
register failed 196608 [10] error(0x30000): OpenIB-cma: DAT_INSUFFICIENT_RESOURCES:
[4:node002][rdma_iba.c:220] Intel MPI fatal error: DTO operation posted for [10:node001] completed with error. status=0x1. cookie=0x4000a
rank 10 in job 1 head_46465 caused collective abort of all ranks
exit status of rank 10: return code 1
The benchmark fails at the start of the HPL part of the benchmark. Any suggestions for fixes would be most appreciated.
Bart
bwillems
Correction: it fails during the PTRANS part of the benchmark.
Bart
Dmitry_K_Intel2
Quoting - bwillems
Bart
Hi Bart,
It's very strange to see that you cannot start HPCC testing because this is quite standard testing. Have you read the article: http://software.intel.com/en-us/articles/performance-tools-for-software-developers-use-of-intel-mkl-in-hpcc-benchmark/ I hope it will be useful.
Might be your system has not enough memory for 16 processes. Have you tried less?
Could you provide details about your cluster?
Best wishes,
Dmitry
Sergey_S_Intel2
Bart
Please try mpirun -nolocal option because Intel MPI starts processes on local host by default.
Sergey
Ron_Reeder
FYI
The following link has an http form to build your parm file (the HPL.dat file). It attempts to build a parm file that will maximize node usage to obtain best FLOP score possible. But, it's also nice in that it builds a parm file that will use the number nodes/cores you want, without having to understand the format of the parm file.
http://lab.advancedclustering.com/hpl.html
