Intel® MPI Library
2273 Discussions
Intel MPI segmentation fault bug
Jamil_A_
 Hi
   I have come across a bug in Intel MPI when testing in a docker container with no numa support. It appears that the case of no numa support is not being handled correctly.  More details below
  Jamil
    icc --version
    icc (ICC) 17.0.6 20171215
gcc --version
gcc (GCC) 5.3.1 20160406 (Red Hat 5.3.1-6)
     uname -a
     Linux centos7dev 4.9.60-linuxkit-aufs #1 SMP Mon Nov 6 16:00:12 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
     bug.c
 #include "mpi.h"
int main (int argc, char *argv[])
   MPI_Init(&argc,&argv);
I_MPI_CC=gcc mpicc -g bug.c -o bug
gdb ./bug
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7b64f45 in __I_MPI___intel_sse2_strtok () from /opt/intel/compilers_and_libraries_2017.6.256/linux/mpi/intel64/lib/libmpifort.so.12
Missing separate debuginfos, use: debuginfo-install libgcc-4.8.5-16.el7_4.2.x86_64 numactl-devel-2.0.9-6.el7_2.x86_64
(gdb) bt
#0  0x00007ffff7b64f45 in __I_MPI___intel_sse2_strtok () from /opt/intel/compilers_and_libraries_2017.6.256/linux/mpi/intel64/lib/libmpifort.so.12
#1  0x00007ffff70acab1 in MPID_nem_impi_create_numa_nodes_map () at ../../src/mpid/ch3/src/mpid_init.c:1355
#2  0x00007ffff70ad994 in MPID_Init (argc=0x1, argv=0x7ffff72a2268, requested=-148233624, provided=0x1, has_args=0x0, has_env=0x0)
    at ../../src/mpid/ch3/src/mpid_init.c:1733
#3  0x00007ffff7043ebb in MPIR_Init_thread (argc=0x1, argv=0x7ffff72a2268, required=-148233624, provided=0x1) at ../../src/mpi/init/initthread.c:717
#4  0x00007ffff70315bb in PMPI_Init (argc=0x1, argv=0x7ffff72a2268) at ../../src/mpi/init/init.c:253
#5  0x00000000004007e8 in main (argc=1, argv=0x7fffffffcd58) at bug.c:6
Dmitry_S_Intel
Hi Jamil,
Can you show
$ numactl -H
Dmitry
Jamil_A_
 Hi Dimitry
 In a Centos 6 Docker container
  > numactl -H
available: 0 nodes ()
libnuma: Warning: Cannot parse distance information in sysfs: No such file or directory
No distance information available.
 In Centos 7 the output is -  numa is not supported on this system
 Jamil
van_Duijn__Mick
Hi Dimitri, Jamil,
Just ran into the same issue today. The system I compile on has no NUMA support
numactl --show
physcpubind: 0 1 2 3 4 5 6 7
No NUMA support available on this system.
When running a program only containing MPI_Init, I similarly get the segfault:
[0,1] (mpigdb) run
[0,1]   Continuing.
[0,1]
[0,1]   Program received signal SIGSEGV, Segmentation fault.
[0]     0x00007f4876dc0805 in __I_MPI___intel_sse2_strtok ()
[1]     0x00007fe059bc0805 in __I_MPI___intel_sse2_strtok ()
[0,1]      from /opt/intel/compilers_and_libraries_2018.2.199/linux/mpi/intel64/lib/libmpi.so.12
[0,1] (mpigdb) bt
[0]     #0  0x00007f4876dc0805 in __I_MPI___intel_sse2_strtok ()
[1]     #0  0x00007fe059bc0805 in __I_MPI___intel_sse2_strtok ()
[0]     #1  0x00007f4876c7ce91 in MPID_nem_impi_create_numa_nodes_map ()
[1]     #1  0x00007fe059a7ce91 in MPID_nem_impi_create_numa_nodes_map ()
[0,1]       at ../../src/mpid/ch3/src/mpid_init.c:1355
[0]     #2  0x00007f4876c7dd74 in MPID_Init (argc=0x1, argv=0x7f4876e2bdb4,
[1]     #2  0x00007fe059a7dd74 in MPID_Init (argc=0x1, argv=0x7fe059c2bdb4,
[0]         requested=1994571188, provided=0x1, has_args=0x0, has_env=0x2)
[1]         requested=1505934772, provided=0x1, has_args=0x0, has_env=0x2)
[0,1]       at ../../src/mpid/ch3/src/mpid_init.c:1760
[0]     #3  0x00007f4876c1eaeb in MPIR_Init_thread (argc=0x1, argv=0x7f4876e2bdb4,
[1]     #3  0x00007fe059a1eaeb in MPIR_Init_thread (argc=0x1, argv=0x7fe059c2bdb4,
[0]         required=1994571188, provided=0x1) at ../../src/mpi/init/initthread.c:717
[1]         required=1505934772, provided=0x1) at ../../src/mpi/init/initthread.c:717
[0]     #4  0x00007f4876c0c07b in PMPI_Init (argc=0x1, argv=0x7f4876e2bdb4)
[1]     #4  0x00007fe059a0c07b in PMPI_Init (argc=0x1, argv=0x7fe059c2bdb4)
[0,1]       at ../../src/mpi/init/init.c:253
Is there any way to manually disable NUMA during compilation?
Kind regards,
Mick
Ben_Held
Any updates on this? We are seeing the same issue under WSL (used for local testing).
Andriy
Same issue here under WSL Ubuntu 18.04 and Intel MPI Library 2018 update 4. forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source prog.exe 00000000032799D4 for__signal_handl Unknown Unknown libpthread-2.27.s 00007FD178B92890 Unknown Unknown Unknown prog.exe 000000000325A805 __I_MPI___intel_s Unknown Unknown prog.exe 0000000003041B9C Unknown Unknown Unknown prog.exe 0000000003042A74 Unknown Unknown Unknown prog.exe 0000000003010E23 Unknown Unknown Unknown prog.exe 000000000300EAB6 PMPI_Init_thread Unknown Unknown prog.exe 0000000002F3A0AE PMPI_INIT_THREAD Unknown Unknown prog.exe 0000000000AAF137 MAIN__ Unknown Unknown prog.exe 0000000000966F2E main Unknown Unknown libc-2.27.so 00007FD178401B97 __libc_start_main Unknown Unknown prog.exe 0000000000966E2A _start Unknown Unknown The issue must be with hydra or something related to MPI initialization on WSL. Because the same exe runs just fine on regular Linux machine. When linked against Intel MPI 2019 Update 1, program runs fine under the same WSL. But startup time is very long.
Alexander_G
I'm also encountering this on an HPC system using a single node:
[0] Program received signal SIGSEGV, Segmentation fault.
[0] 0x00007ffff60c3636 in strtok_r () from /lib64/libc.so.6
[0] (mpigdb) bt
[0] #0 0x00007ffff60c3636 in strtok_r () from /lib64/libc.so.6
[0] #1 0x00007ffff7b58561 in __I_MPI___intel_sse2_strtok ()
[0] from /impi/2018.5.288-iccifortcuda-2019b/lib/libmpifort.so.12
[0] #2 0x00007ffff70e81f5 in MPID_nem_impi_create_numa_nodes_map ()
[0] at ../../src/mpid/ch3/src/mpid_init.c:459
[0] #3 0x00007ffff70eaf86 in MPID_Init (argc=0x0, argv=0x7ffff7299254,
[0] requested=-163687992, provided=0x0, has_args=0x41b210, has_env=0x407012)
[0] at ../../src/mpid/ch3/src/mpid_init.c:1771
[0] #4 0x00007ffff708bbc3 in MPIR_Init_thread (argc=0x0, argv=0x7ffff7299254,
[0] required=-163687992, provided=0x0) at ../../src/mpi/init/initthread.c:717
[0] #5 0x00007ffff707913b in PMPI_Init (argc=0x0, argv=0x7ffff7299254)
[0] at ../../src/mpi/init/init.c:253
[0] #6 0x00000000004012be in main ()
$ numactl -H
available: 8 nodes (0-7)
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 104 105 106 107 108 109 110 111 112 113 114 115 116
node 0 size: 64078 MB
node 0 free: 59732 MB
node 1 cpus: 13 14 15 16 17 18 19 20 21 22 23 24 25 117 118 119 120 121 122 123 124 125 126 127 128 129
node 1 size: 64505 MB
node 1 free: 63486 MB
node 2 cpus: 26 27 28 29 30 31 32 33 34 35 36 37 38 130 131 132 133 134 135 136 137 138 139 140 141 142
node 2 size: 64505 MB
node 2 free: 61897 MB
node 3 cpus: 39 40 41 42 43 44 45 46 47 48 49 50 51 143 144 145 146 147 148 149 150 151 152 153 154 155
node 3 size: 64505 MB
node 3 free: 63400 MB
node 4 cpus: 52 53 54 55 56 57 58 59 60 61 62 63 64 156 157 158 159 160 161 162 163 164 165 166 167 168
node 4 size: 64505 MB
node 4 free: 62791 MB
node 5 cpus: 65 66 67 68 69 70 71 72 73 74 75 76 77 169 170 171 172 173 174 175 176 177 178 179 180 181
node 5 size: 64505 MB
node 5 free: 63732 MB
node 6 cpus: 78 79 80 81 82 83 84 85 86 87 88 89 90 182 183 184 185 186 187 188 189 190 191 192 193 194
node 6 size: 64505 MB
node 6 free: 63578 MB
node 7 cpus: 91 92 93 94 95 96 97 98 99 100 101 102 103 195 196 197 198 199 200 201 202 203 204 205 206 207
node 7 size: 64436 MB
node 7 free: 63722 MB
node distances:
node   0   1   2   3   4   5   6   7
  0:  10  12  12  12  21  21  21  21
  1:  12  10  12  12  21  21  21  21
  2:  12  12  10  12  21  21  21  21
  3:  12  12  12  10  21  21  21  21
  4:  21  21  21  21  10  12  12  12
  5:  21  21  21  21  12  10  12  12
  6:  21  21  21  21  12  12  10  12
  7:  21  21  21  21  12  12  12  10
Any solution here?
Alexander_G
I investigated a bit further into the call to `strtok_r` and found that it passes a NULL pointer in seemingly the 5th call which explains the segmentation fault but not why that null pointer is passed.
TobiasK
@Alexander_G
please do not post to such old threads, please create a new one instead.
Please also include the information required to reproduce the problem, including SW and hardware details.
