Intel® MPI Library
2296 Discussions
Intel oneAPI mpirun error in Ubuntu 20.04.3
ousam2023
I have an installation of intel oneAPI version 2021.4 via Ubuntu 20.04.3LTS. Everything used to be run well. but somehow, something bugging me is that I can't run my mpirun.
For instance:
What causes this behavior? How do I solve it?
VarshaS_Intel
Could you please let us know the output by using the below command?
which mpirun
And also, the MPI version you are using with the following command?
mpirun --version
Also, try exporting the PATH by using the output of the "which mpirun":
export PATH=<output-of-which-mpirun>:$PATH
Example: export PATH=/opt/intel/oneapi/mpi/2021.4.0//bin/mpirun:$PATH
After that, check and let us know the MPI version using the command:
mpirun --version
Thanks & Regards,
Varsha
ousam2023
Great thanks for your help!
Here is my screen capture after following your advice:
and I also post my ubuntu kernel which I think will help.
Thanks & Regards,
Ousam
VarshaS_Intel
Thanks for providing the details.
Could you please try giving the complete path(output of the "which mpirun") while running the mpi code?
Example:/opt/intel/oneapi/mpi/2021.4.0//bin/mpirun --version
/opt/intel/oneapi/mpi/2021.4.0//bin/mpirun -n 2 hostname
Could you please try and let us know if you are able to run without hanging?
If possible, could you please try the latest Intel MPI Library(2021.8)?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Varsha
ousam2023
Sorry for reply you so late,I just finished my vacation.
Here is the screen after following your advise. 
My mpirun used to executed well until something upgrade in my Ubuntu (I guess) .
I have no idea what is happended in my systems.
It seems to jam in the mpiexec.hydra which is mpirun's api, but no mpirun in the system process.
Thanks & Regards,
Ou sam
VarshaS_Intel
Thanks for the update.
As we mentioned before, could you please try using the Intel MPI latest compiler(2021.8) and run the sample hello world code?
Please find the links for the installation of the Intel Base Toolkit and Intel  HPC Toolkit.
Please let us know if your issue still persists.
Thanks & Regards,
Varsha
ousam2023
Thanks for the advice.
The problem was solved after I installed the latest oneAPI version.
I don't reinstall it at first because it will make me recompile all my software, which is the toughest task in the world (sigh).
I think it may relate to intel mpi 2021.4.0's weird bug.
Overall, appreciate your help!
Thanks & Regards,
Ou sam
VarshaS_Intel
 Glad to know that your issue is resolved. This thread will no longer be monitored by Intel. If you have any other queries, please start a new thread.
Have a good day!
Thanks & Regards,
Varsha
