Intel® MPI Library
2274 Discussions
Linux Cluster with intel DQ35JO board and Core 2 Duo processor????? Is creating problem.....
Muhammad_Asif
I have designed the simple beowolf cluster of 16 nodes by using intel DQ35JO mother board and intel core 2 Duo processors. The problem is, i can't run the climate models on more than six nodes. When I start the model by using more no. of processors in mpd.hosts, it fails or don't give correct results. Moreover, simple mpi programs are working well with this cluster. Plz help me....
Asif
Gergana_S_Intel
Hello Asif,
There are numerous causes for your application to not be able to run on your cluster. We certainly need more information regarding this issue (what software are you using - MPI implementation, compiler, libraries, etc; are you using an interconnect - IB, Quadrics, Myrinet, etc). Also information on the error or failure you're getting would be helpful.
If you believe this might be a software issue, I would suggest that you submit a bug report at the Intel Premier Support site at http://premier.intel.com.
~Gergana
Gergana Slavova
Technical Consulting Engineer
Intel Cluster Tools
E-mail: gergana.s.slavova_at_intel.com
