Intel® MPI Library
2284 Discussions
MPI_GATHERV hangs for non-root process sending zero data
Christopher
I am using Intel OneAPI version 2021.3.0 20210609.
When calling MPI_GATHERV, a non-root process sending zero information does not exit the MPI_GATHERV call (i.e. it hangs). All other processes complete, and the root process gathers all the data correctly.
Note that the root process always has zero information in it's send buffer as it is a manager process. That is why I explicitly state above this issue is only related to a non-root process sending zero information.
Wrapping the call to MPI_GATHERV with an if statement that sends `MPI_BOTTOM` in as an argument seems to fix the issue. But I don't understand why this is necessary:
 if (self%is_manager() .OR. dim1_size .gt. 0) then
    call MPI_GatherV(gather_variable,int(dim1_size,kind=MPI_INTEGER_KIND),datatype, &
     gathered_result,int(dim1_size_gathered,kind=MPI_INTEGER_KIND),displs,datatype, &
            self%manager_id,self%comm,ierror)
 else
    call MPI_GatherV(MPI_BOTTOM,int(dim1_size,kind=MPI_INTEGER_KIND),datatype, &
 end if
Labels (2)
VarshaS_Intel
Could you please provide the system environment details?
And also, could you please provide the complete sample reproducer code so that we can investigate more on your issue?
Thanks & Regards
Varsha
VarshaS_Intel
We haven't heard back from you. Could you please provide the details mentioned in the previous post?
Thanks & Regards
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Varsha
