Intel® MPI Library
2241 Discussions
Malfunctioning of some MPI subroutines with Ifort Compiler for Windows
Ines_F_
I started recently programming with the MPICH2 library associated to the Intel Visual Fortran composer for Windows. Even if my test code recognize the MPI library, many of the MPI simple subroutines didn't work, even well set ! For example, this simple code didn't create the file 'data.txt' :
program main
        use mpi
        implicit none
        integer :: descripteur,code
        call MPI_INIT(code)
        call MPI_COMM_SIZE ( MPI_COMM_WORLD ,nb_procs,code)
        call MPI_COMM_RANK ( MPI_COMM_WORLD ,rang,code)
      print * ,'Je suis le processus ',rang,' parmi ',nb_procs
        call MPI_FILE_OPEN(MPI_COMM_WORLD,"data.txt",MPI_MODE_RDWR+MPI_MODE_CREATE,MPI_INFO_NULL,descripteur,code)
        call MPI_FILE_CLOSE (descripteur,code)
        call MPI_FINALIZE (code)
end
Result :
Je suis le processus            5  parmi            8
 Je suis le processus            3  parmi            8
 Je suis le processus            1  parmi            8
 Je suis le processus            7  parmi            8
 Je suis le processus            6  parmi            8
 Je suis le processus            2  parmi            8
 Je suis le processus            4  parmi            8
 Je suis le processus            0  parmi            8
But the file data.txt isn't created !
Can someone please help me ! why such a simple code do not work ?
Thanks a lot.
