Intel® MPI Library
2287 Discussions
Mallanox WinOF & Intel MPI On Windows
AaronONE
I try to run my program using the following commands
mpiexec -n 2 -hosts 2 MACHINE-01 MACHINE-02 mpitest_c.exe
However, it prompts me saying that the dapl fabric is not available.
I have verified that the Mallanox WinOF is installed.
However, I cannot find the file /etc/dat.conf.
Is it being renamed and placed in other directories?
Or is there other issues that I need to take note of?
TimP
With only 2 nodes, wouldn't rdma be better than dapl? I assume you have it working with socks.
Dmitry_K_Intel2
The correct command line should look like:
mpiexec -hosts 2 PHITEN-01 #of_processes1 PHITEN-02 #of_processes2 mpitest_c.exe
In your case it should be:
mpiexec -hosts 2 PHITEN-01 1 PHITEN-02 1 mpitest_c.exe
dat.conf may be located in different directories - it depends on your installation. Please check "c:\DAT" directory.
WinOF may also be located in different directories but usually it resides in "c:\program files\winof"
Regards!
Dmitry
AaronONE
Good Day,
I have discovered that Mallanox WinOF 2.0.7 on Windows 2003 does not have the DAT functionality.
What I have done is to install the generic installer that is available in OpenFabrics Alliance.
But remember to update the firmware for your HCA connector.
Dmitry_K_Intel2
Thanks, Aaron, for sharing with us!
---Dmitry
